Changelog Madsonic Server
Posted: 10 Dec 2012, 18:36
CHANGELOG
Change-log 5.0 Branch
Build 3830
Update: Fixed Mediascanner Exceptions
Update: Update ffmpeg version 32/64bit
Build 3820
new: encoded password passthrough logon
Update: Updates for Madsonic 5.5.200 Client (REST API)
Update: Fixed slow DB-Queries (Starred, Playlist)
Update: Update REST-API 0.10.5
Update: Fixed Playlisteditor Links
Update: Fixed Theme issues
Update: Fixed comment file read error
Update: Theme preview function
Build 3800
new: many Layout-changes
new: Albumviews: by decade, by genre
new: Discover Updates (Artist Description)
new: speedup Discover requests
new: update REST API 1.10.5 (support new list requests)
new: fixed rare null exception (Bug-reports)
new: support for MOD music files
new: support new trans-coding profiles
new: support new trans-coders
new: support Android deep app links
Update: fixed some podcast problems if xml are corrupt
Update: fixed jukebox-mode default gain bug
Update: many Madsonic Theme Updates
Update: Update windows ffmpeg version 32/64bit
Update: included new encoder tools
Update: included minisub & jamstash
Update: Update jetty server 8.1.14.v20131031
many more ...
Build 3780
new: more Discover Feature (last top played, last played)
new: update REST API 1.10.2 (support lyric requests with mediafile ids (for upcoming Android Update 5.5)
Update: fixed broken Feature 'read from comment file'
Update: fixed broken Feature 'define Logfile level'
Update: artist.view - rearrange elements
Update: db.view - insert SELECT TOP(1000) protection limit
Update: edittags.view - fixed colspan
Update: some Madsonic Sunny Theme Updates
Build 3760
new Feature: read unsyncedlyrics from local metadata, fallback to chartlyrics
new Feature: within social tab new lyrics popup design
Update: Update Jquery 1.10.2
Update: Update many project files
Update: BUG: Chartlyrics search don't work
Update: BUG: Profile/Default user handling
Build 3750
new Feature: Mac OS X native installer
new Feature: Java 1.6/1.7/1.8 compatible
Update: some Theme Updates
Update: Fixed Save on Default User
Merge: [r3506] Make Enter work when searching lyrics.
Merge: [r3505] Show throttle warning in lyrics popup.
Merge: [r3503] Set hsqldb.cache_file_scale=8 for new databases. (should prevent S1000 General DB errors)
Merge: [r3502] Add "Play next"
Build 3740
*) new Feature: new Theme Madsonic Sunny
*) new Feature: new accountService
*) new Feature: new default user/settings system
*) new Feature: new setting to Disable User (Logon)
*) new Feature: edit each user settings as admin
*) Update: Last Build FFMPEG (windows/linux/standalone)
*) Update: tuned some Theme issues
Build 3710
*) Update: Madsonic french translation - Contribution from User breakolami - http://forum.madsonic.org/viewtopic.php?f=30&t=754
*) Update: BUG: PlayQueue loops between identical items - very old one (c;=
*) Update: BUG: wrong jquery Template (B3700)
*) Update: BUG: new Playlist/Media Tools/Cleanup Pages doesn't with subcontent url (B3700)
*) Update: tuned Last.FM Queries
Build 3700
*) new Feature: new (Codename: Pandora) search logic
*) new Feature: new (Codename: Pandora) search settings
*) new Feature: optimize logging/visual settings
*) new Feature: internal Tag Editor Mood-Support (experimental)
*) new Feature: split Playlist Page into Listview & Editor Page
*) new Feature: split Cleanup Page into Playlist / Media Tools / Cleanup Pages
*) new Feature: new usersetting for Mood-Support on Main & PlayQueue Frame
*) new Feature: add new settings for Playlist-editor
*) Update: upgrade setup to jetty server 8.1.12 (experimental)
*) Update: upgrade madsonic-booter.jar for new jetty container
*) Update: new dedicated madsonic-tomcat.war for tomcat 7.x installations
*) Update: upgrade old project library files
Build 3660
*) new Feature: Pandora Playmode
*) new Feature: LAST.FM Artistinfo auto-detect
*) Update: Theme: Madsonic White Theme Update
*) Update: Log: moved many log entries from INFO -> DEBUG
*) Update: Settings: optimize some Default values
*) Fix: PlayQueue: Repeat-Mode doesn't display mode correctly
Build 3650
*) Merge: [r3501] Use placeholder for search input field.
*) new Feature: native x64 installer version incl. ffmpeg (needs Java 64 bit)
*) new Feature: define Logfile Level (OFF, ERROR, WARN, INFO, DEBUG)
*) new Feature: expand Groupsettings (700kbps, 1200kbps, 1500kbps)
*) Fix: SSL Fix: Recover Page
*) Fix: SSL Fix: Google Font css
Build 3630
*) new Feature: complete Madsonic Rebranding
*) new Feature: Move to \Madsonic (to prevent Problems with subsonic installs)
*) new Feature: Support for Java Heapsize initial Size (Madsonic Booter & Scripts)
*) new Feature: Disable Albumset parsing (General Settings) Full Rescan required!
*) new Feature: Setting to show Log in reverse order
*) new Feature: Artisthub: new visual Albumcount
*) new Feature: Split Full Scan (with/without Cleanup)
*) Update: Madsonic Booter & shell scripts
*) Fix: Random Page doesn't contain duplicates
*) Fix: Null Exception on Mediascan
*) Fix: Full Scan doesn't work all the time
*) Fix: custom Setting Home.view doesn't work (Main Frame)
Build 3600
*) Merge: [r3499] DLNA settings
*) Merge: [r3496] Bugfix: Creates new player for each download.
*) Merge: [r3495] Fix download file names with special characters
*) Merge: [r3489] Add CAPTCHA to password recover.
*) Merge: [r3487] cover.view doesn't set mime type
*) new Feature: Coordinate Main Panel with left column selector (Random, New, Hot)
*) new Feature: Disable Folderparsing -> truncated Year (General Settings) Full Rescan required!
*) new Feature: Disable DLNA Server (DLNA Settings)
*) Update: NSIS Installer 3.0 Upgrade
*) Update: Theme Icon Updates
*) Update: booter & shell scripts
*) Update: JWPlayer 6.6 Update
*) Fix: broken Comment Format Function (Main Frame)
Build 3572
*) Fix: support for multiple genre & moods (supported sperators | ; , //)
Build 3570
*) Fix: unescape Genre (Left Frame)
*) Fix: Fixed Range handling
*) Fix: Disable Range requests while transcoding
Build 3560
*) new Feature: Quick Play/Add Buttons on Albums
*) new Feature: basic support for multiple genre & moods (truncate after first ';')
*) new Feature: Advanced Coverart (scale/crop)
*) new Feature: Advanced Folder parsing (Year)
*) new Feature: some Theme Updates
*) new Feature: cached Genre Radio for faster access
*) new Feature: Genre Filter on Left Frame
*) new Feature: all Covers are clickable
*) new Feature: Cover Last Starred (all clickable)
*) new Feature: Advanced Statistics (Statistics for each media folder)
*) new Feature: Advanced Playlist Tools
*) new Feature: Playlist Left-Frame Disabled (General Settings)
*) new Feature: RPM Build should work with older rpmbuild version
*) Update: last Build ffmpeg
*) Fix: false Query REST API
*) Fix: Genre Filter
*) small Bugfix
Build 3510
*) new Theme: Madsonic Pink
*) Update: Fix Start Scripts
*) Update: Fix Upload Folder can't set
*) Update: Fix Null Exception
*) Update: Fix SQL Query
*) Update: Last.FM API (Since Value)
*) Update: Artist schema (genre)
*) Update: Custom Scrollbar on Log Page too
Build 3500
*) new Feature: Setting for Upload Folder (also via script)
*) New APIs for Madsonic Client 5.3 (Artist Genre)
*) Update REST API
*) Update id3 REST API Calls
*) Update getRandomSongs API Calls
*) Update Security fix for all Artist View
*) Update: last Build jwplayer 6.10
*) Bugfix
Build 3490
*) new Feature: Merged HTML5 & Flash Version (Video)
*) new Feature: option to change to HTML5 playback (General)
*) new Feature: option to select own genrelist (Tagedit)
*) new Feature: option to reset Transcoder settings (Tools)
*) Notification Bugfix
Build 3480
*) New APIs for Madsonic Client 5.2
*) Update REST API 1.10.1
*) new Feature: All Artist View
*) new Feature: Starred Artist
*) moved some text to translation files
*) fixed FLAC native to Clients Bug (transcodingService)
Build 3470
*) Update FFMPEG
*) Experimental UPnp/DLNA Server
*) Update REST API to 1.10.1
*) new Feature: Play Album directly in home view
*) Fix incasesensitive Genre in REST API
*) New Bookmark REST API
*) Added IgnoredArticles to REST API
*) Tuned some Scrollbars
*) Bugfix
Build 3460
*) Madsonic 5.0 Client Support
*) Subsonic 4.8 API support
*) Update REST API to 1.9.5
*) Fixed unescaped Genre API
*) Fixed some other small issues
*) Theme Madsonic Holotron Rework
*) new Feature: Export all Playlists
*) new Feature: File History (Audio, Podcast, Video)
*) Project Butter (new CustomScrollBar Rework)
*) new Theme Madsonic Tron
*) big other Theme Updates
*) Subsonic-booter Update
*) History Icon configurable
*) Bugfix Release
*) add new Avatar Icons
*) Bugfix Playqueue CustomScrollbar
*) Update French Translation
*) REST API 1.9.2
*) Last.FM Interface-Bug
*) JQuery 1.9 Migration
*) JQueryUI 1.10.2 Migration
*) Cleanup CSS Templates
*) Refactor Theme Template
Changelog 4.8 Branch
Build 3360
NEW: Feature: Icon Setting also for adminuser (configurable)
NEW: Update: new French Translation (User: lanzari)
NEW: Update: update German Translation
NEW: Update: update Norwegian Translation
NEW: Update: update Swedish Translation
NEW: Update: update Spanish Translation
NEW: Update: update Finnish Translation
NEW: Update: Upgrade to latest ffmpeg version (Win/Linux)
NEW: Update: Upgrade to java installer version to 1.7_17
Build 3350
NEW: Update: Typo on Fedora-install
Build 3348
NEW: Feature: Last.FM Match
NEW: Update: Jquery/Jquery UI Fixes
Build 3340
NEW: Update: Revert some Jquery Updates (Scroll-Fix)
Build 3338
Build 3336
NEW: Feature: Artist Hub Detail-view
NEW: Feature: Artist TopTag Radio
NEW: Feature: Moods Radio (if Audio Tag Support this)
NEW: Feature: Last.FM Sync Service for Artist Info & more
NEW: Feature: New Setting: howto show Shortcuts
NEW: Feature: Testfiles for HTML5 Player
NEW: Feature: REST: startRescan, scanstatus
NEW: Theme: Updates Themes
NEW: Update: http://sourceforge.net/p/subsonic/code/3336/
NEW: Update: http://sourceforge.net/p/subsonic/code/3335/
NEW: Update: http://sourceforge.net/p/subsonic/code/3334/
NEW: Update: http://sourceforge.net/p/subsonic/code/3317/
NEW REST APIs: startRescan, scanstatus
EXAMPLE:
RESULT:
Build 3320
NEW: Feature: Changed TranscodingService (Native Support for Clients)
NEW: Feature: Default Video Bitrate via Security Groups
NEW: Feature: mark new added Album with New-Icon
NEW: Feature: Add Playlist instead of only Play
NEW: Feature: Updated New Version avilable
NEW: Feature: REST API Update to Rescan Mediafolders
NEW: Theme: SigelSonic Update 1.0
Build 3312
NEW: Theme: Big Updates to many Themes
NEW: Theme: Reskin Theme "Barents Sea" for Madsonic
NEW: Theme: SigelSonic Updates
NEW: Update: Update JQuery UI template
NEW: Update: Make Themes more Skinable
Build 3310
NEW: Feature: Madsonic now supports Installation on Tomcat 6.0.35/Tomcat 7.0.34
NEW: Feature: create named Playlist from main.view
NEW: Update: Update Podcast REST Api
NEW: Theme: SigelSonic Update 0.5
NEW: Update: ThreeJS v0.54
Build 3306
NEW: Feature: Enable/Disable Default ArtistCover
NEW: Update: SigelSonic Theme Updates
Build 3304
NEW: Feature: new Usersetting Audiohide Chat-Panel
NEW: Update: Chat-Panel Text wrap around Fix
NEW: Update: SigelSonic Theme Custom Accordion
NEW: Update: many Theme/Css Fixes
NEW: Update: REST API 1.9.0
NEW: Update: HLSController Update Fix
NEW: Update: MiniSub to 2.3.8 https://github.com/tsquillario/MiniSub
Build 3300 Beta3
NEW: Update: Add JQuery UI template
NEW: Update: less aggressive Tracknumber Filter
NEW: Feature: new Sorting File/Album Sorting Options
NEW: Feature: Autoreimport external Playlists if changed on Rescan
NEW: Feature: new Mediafile Version System
NEW: Feature: new Madsoni Last.FM API Cache Service (Coverart)
NEW: Update: Update Coverart Service
NEW: Update: Update Albumset Scan
NEW: Update: Update ffmpeg
NEW: Update: Update Jquery 1.8.3
NEW: Update: Update to jaudiotagger 2.0.4.SNAPSHOT
NEW: Update: Update REST Api
NEW: Update: new Version Service
Build 3292
NEW: Theme: Madsonic Corporate
NEW: Update: Fixed missing JQuery UI template
Build 3290
NEW: Feature: Playlist Easy Share (for example Greeting Cards)
NEW: Update: Fixed duplicated Entries in PlayQueue Bug (Radio.view)
Build 3288SE
NEW: Special Build: Reverted to Java 1.6 compiled version
Build 3288
NEW: Feature: Folderselection Sort is now configurable (GeneralSettings.view)
NEW: Feature: Cleanup File Logging
NEW: Update: Fixed Access Default Rights (MediaFolder or Group) Reset Access Rights no more needed!
NEW: Update: Fixed Scanning
Build 3280
NEW: Feature: Madsonic Artist Hub
NEW: Feature: Custom Arrcordion in Left Frame
NEW: Feature: better Sorting (Year, Foldernames, Filenames, REST, ..)
NEW: Feature: Set Default Icons for Top Frame
NEW: Feature: Artitsts stretched over several mediaFolder, now correctly sorted
NEW: Feature: Folderselection is now sorted
NEW: Feature: nicer Logon View
NEW: Feature: Save all Title to Playlist directly from Dropdown
NEW: Feature: Redesign Left Frame, (show/hide) Statistics & Shortcuts
NEW: Update: Fixed Access Right if new MediaFolder is added
NEW: Update: Fixed Scanning Error
NEW: Update: Fixed broken REST Errors
NEW: Update: some Theme Updates
NEW: Update: Update Jquery UI 1.9.2
NEW: Update: MiniSub to 2.3.4 https://github.com/tsquillario/MiniSub
Build 3220
NEW: Update: Fixed Jaudiotagger Parsing Error
NEW: Update: Fixed MediaFileScanner Error
Build 3218
NEW: Update: Fixed MetaDataParser Bug if Year is in format 2012-05-07
NEW: Update: Fixed MediaFileScanner Bug if Artist have no Tags
NEW: Update: Podcast Downloader increased to 5 downloads simultaneously
NEW: Update: trimmed REST Filter Errors on broken Streams
NEW: Update: add Tip & Alphabetically View to Listtype (personalSettings.view)
NEW: Update: Jaudiotagger updated
Build 3216
NEW: Feature: Use Subsonic Premium Redirection Services or Share with your own Domain (optional in GeneralSettings.view)
NEW: Feature: Sort Files by Filenames (default is alphabetically) (optional in GeneralSettings.view)
NEW: Feature: Set Default Leftframe Size (optional in GeneralSettings.view)
NEW: Feature: Set Default PlayQueueframe Size (optional in GeneralSettings.view)
NEW: Update: some Updates to Sonic-Theme
Build 3210SE
Build 3210
NEW: Feature: Advanced Media Library Statistics. (correct artist/album Counts) http://forum.subsonic.org/forum/viewtop ... 495#p48495
NEW: Update: Sort folder by foldernames works also on Artist folder
NEW: Update: Fix TYPO on cleanupSettings.view
NEW: Update: directwebremoting 3.0.0-rc3-SNAPSHOT
Build 3206
NEW: Feature: Sort albums by foldernames (optional in GeneralSettings.view)
NEW: Update: CleanupSettings.view
Build 3204
NEW: Update: Fixed REST API Calls - Access Control
NEW: Update: Fixed Random-Search Function - Access Control
NEW: Update: Fixed Radio Random title Code - Access Control
Build 3200
NEW: Feature: Madsonic Media-Folder Access Control http://forum.subsonic.org/forum/viewtop ... 15&t=10491
NEW: Feature: Support for Subtitle on Videos (Example: <videofile>.srt) http://forum.subsonic.org/forum/viewtop ... 460#p47498
NEW: Feature: Import from each folder a comment.txt into Album-Comment field http://forum.subsonic.org/forum/viewtop ... 15&t=10573
NEW: Feature: New Cleanup-Tools Page (Settings.view)
NEW: Update: MiniSub to 2.2.7 https://github.com/tsquillario/MiniSub
NEW: Update: Upgrade to latest ffmpeg version 31.10.2012 (Win/Linux)
NEW: Update: Upgrade to latest java libraries (DWR, common-io)
NEW: Update: standalone Transcoding Pack -> (http://uploaded.net/f/sctmqc)
Changelog 4.7 Branch
Build 3158
NEW: Update: MiniSub to 2.1.7 https://github.com/tsquillario/MiniSub
NEW: Update: enabled Step3 for transcoding
NEW: Update: Bugfix Flac/m4a transcoding
NEW: Update: for better split transcoding on linux/windows to: Audioffmpeg -> audio, ffmpeg -> video
NEW: Update: Update Rest API for Tips
Build 3155
NEW: Update: Update transcoding m4a/flac Transcoding Packs -> (http://uploaded.net/f/sctmqc)
Build 3154
NEW: Update: Filetaging: to auto overide the mediatype use:
NEW: Feature: Exclude files and folders listed in a madsonic_exclude.txt file (put in each line a folder/filename to exclude)
NEW: Feature: Search in left.view is pinned to top
NEW: Feature: in home.view new random Tip-View from Top Recommended Albums
NEW: Feature: grouped all Statistics together in status.view
NEW: Feature: now as Default the Playlist Overflow is hidden in left.view
NEW: Feature: in General-Settings the Playlist Path Setting are back (for later Autoexport Feature)
NEW: Update: Upgrade to latest ffmpeg version 10.10.2012 (Win/Linux)
NEW: Update: new transcoding settings for FLAC & SubWiji
NEW: Update: db.view link to new table transcoding2, player_transcoding2
FIX: jump to anchor is overlapped in left.view
FIX: Update: resolved many Theme Issues[/color]
Build 3146
NEW: Feature: in edittags.view now you can edit the AlbumArtist value (Various Artists)
NEW: Feature: in left.view new Options 'Show All', 'Hide All', 'Show Some' for Playlists
NEW: Feature: User-Role 'Search' to cut down the interface for guests
NEW: Feature: User-setting 'CustomScrollbar' to enable/disable for each user
NEW: Theme: 'Madsonic Kids' to test some new CustomScrollbar Styles for -webkit Browser (Chrome)
NEW: Update: db.view - Better Layout
NEW: Update: log.view expand to 500 lines
FIX: Update: playQueue - Scrollbar Fix
FIX: Update: Append Starred Items to Playlist Fix
FIX: Update: db version Upgrade
Build 3132SE
Build 3132
NEW: Feature: Save Starred Items to Playlists
FIX: Update Theme issues
NEW: Update booter.jar
Build 3130SE
Build 3130
NEW: Feature: Use 4 different Index Styles for each Music folder Content http://forum.subsonic.org/forum/viewtop ... 229#p46236
NEW: Update: common.io 2.4
NEW: Update: junit 4.8.2
FIX: Update Starred Queries for speedup
FIX: Update some Theme issues
Build 3124
NEW: Update Scan Progress visible in Top Frame
NEW: Update: Springframework 2.5.6.SEC03
NEW: Update: acegi-security 1.0.7
NEW: Update: common.langs 2.5
NEW: Update: HSQLDB 1.8.0.10
NEW: Update: HTTPClient 4.2.1
NEW: Split About & Log View
NEW: Code Cleanup
Build 3120
NEW: Optimize Database Upgrade from Subsonic 4.6, 4.7, 4.7 Betas (Now you can migrate your old DB) thanks to hakko
NEW: Mashuped Theme SubStandard, Cool and Clean
NEW: Update Carousel (Resize), Random View
NEW: Update some little Theme issues
Build 3112
NEW: Merged uncommitted Final Changes
NEW: *) Comment delete Play-count Fix
NEW: *) Playlist-import Fix
NEW: *) Scrobble Fix
Build 3110
NEW: Merge to latest SVN Branch http://subsonic.svn.sourceforge.net/vie ... ision=3091
FIX: Update JSP to work in IFrame
NEW: Revert to older Linux ffmpeg (works best with flac, m4a, ...)
NEW: Revert to older Windows ffmpeg (works best with flac, m4a, ...)
Build 3106
FIX: Update 'Back in Black' Theme issues
NEW: Include MiniSub 2.0.6
FIX: fixed REST API for MiniSub
NEW: fixed Similar Artists CSS Styles
FIX: finally fixed jumping & bouncing Scrollbar
FIX: Prevent Player Cache Issues
NEW: Update Linux ffmpeg - 20120904-static.32bit
NEW: Update Windows ffmpeg - 20120903-git-5d55830-win32-static
Build 3102
NEW: Tweaked Search-function (Now you can use Wildcard at beginning, Example: *40 -> UB40, Apollo 440)
FIX: fixed broken REST Video-page
FIX: fixed Similar Artists View!
NEW: JQuery 1.8.1 Update
NEW: JQuery UI 1.8.23 Update
FIX: hopefully fixed jumping & bouncing Scrollbar
Build 3100
NEW: New Feature to set recommend Albums for Carousel
FIX: Bugfix broken Create Shares Buttons
NEW: Left Frame Refresh Link
NEW: wtv File Support
FIX: some GUI Fixes
Build 3098
NEW: New Feature to enable/disable Album Year in main.view (General Settings)
NEW: New Feature to enable resizing on LeftFrame (Personal Settings)
NEW: Fix Bug autowidth in LeftFrame (Browser-Zoom)
NEW: Fix Genre serialization on Radio Tags (Radio)
NEW: Fix broken Comment Function (Main)
NEW: Update MediaType detection (File Tags)
NEW: Update MediaType Selection enabled only for Coverart/Tag Admins (Secruity)
Build 3092
NEW: Update to latest ffmpeg build
NEW: New Feature to enable resizing on PlayQueue Frame
NEW: Fix IE Bug to prevent display Custom Scroller
NEW: Fix Theme "Back on Black" Playericons
NEW: Fix Iconpath on Videoplayerpage if not root content is used
NEW: Disable GZIP Filter, prevent startup on Tomcat6
NEW: DB Link in Top only enabled for Admins
Backlog
NEW: Add Custom Scroller to: Home, Main, Starred and Radio View
NEW: Fix Custom Scroller (some Overlay Bugs)
NEW: Fix all Themes to work with Custom Scroller
NEW: Fix Custom Scroller (some Bugs with Firefox)
NEW: Fix Theme Selection don't work on linux
NEW: Update .deb and .rpm packages
NEW: Complete rework of Custom Scroller (works now better on scrolling, resizing, new Content)
NEW: Merge SVN Commits 3030-3083 (beta3) http://www.subsonic.org/pages/changelog.jsp
NEW: Update Jquery UI 1.8.22
NEW: some Mod Codecleanup
NEW: Better Layoutsupport for Android Tablets
NEW: Fixed slow "Top rated" http://subsonic.svn.sourceforge.net/vie ... ision=3030
NEW: Update to JWPlayer 5.10
NEW: Update to FFmpeg git-c17808c 32-bit Static (windows)
NEW: Update Windows Installer package with JRE 1.7
NEW: Theme split: Madsonic (dark), Madsonic (black)
NEW: Updated Slovenian translation http://subsonic.svn.sourceforge.net/vie ... ision=3022
NEW: Autoimport Playlists http://subsonic.svn.sourceforge.net/vie ... ision=3023
NEW: Fixed problem with content removing and re-adding http://subsonic.svn.sourceforge.net/vie ... ision=3024
NEW: Clean-up database function http://subsonic.svn.sourceforge.net/vie ... ision=3027
NEW: First Build with JDK 1.7.05
NEW: Update exe4j 4.4.5
NEW: Update Jquery 1.7.2
NEW: Update Jquery UI 1.8.21
NEW: Update JWPlayer 5.9.2268
NEW: Update Externalplayer (new Skin, Next & Previous Button are back)
NEW: Sinkable Scrollbars (Left & Playqueue Frame)
NEW: Bugfix Playqueue jumps to top on next Button
NEW: Optimize AlbumArtist Tag reading
NEW: temp. disable broken Similar Artist Function (come back soon)
UPDATE: Code Cleanup
UPDATE: Merge to latest SVN Branch
NEW: Advanced User History
NEW: Advanced Albumset Visualization
NEW: Advanced parse/truncate/order Year Tag from Folder structure
UPDATE: Statistics
FIXED: Scanservice/TruncateYear Error
UPDATE: to FFmpeg git-fce30d8 32-bit Static (24.05.2012)
UPDATE: Getting Started.html Link -> Port 4040
UPDATE: to JWPlayer 5.9 Build 2206
Changelog 4.6
Build 2625
FIXED: Code Cleanup
FIXED: broken Dependency to booter.jar
Backlog
NEW: Default/Own Domain Sharing
FIXED: fixed externalPlayer (disable Revolt-Plugin if first Playlistentry is a video)
FIXED: smilar Artist showed in Right Frame
FIXED: fixed Link Colour in Themes
FIXED: add "2 minutes to midnight" Theme
FIXED: Revolt Plugin is default off if playing/sharing Video (External Player)
FEATURE: Make browser blink when there is a new chat message (Right Frame)
FIXED: fixed the Slick Theme
FIXED: Default Theme Iconsize
FIXED: Windows & Linux compatiblity in UploadPath
FIXED: IE9 dont need compatiblity mode to view correct Coverart
FEATURE: You can set in GenerallSettings the default listType Value for new Users
NEW: nicer Star/Rating Icons
Build 3830
Build 3820
Build 3800
many more ...
Build 3780
Build 3760
Build 3750
Build 3740
Build 3710
Build 3700
Build 3660
Build 3650
Build 3630
Build 3600
Build 3572
Build 3570
Build 3560
*) small Bugfix
Build 3510
Build 3500
*) Update REST API
*) Bugfix
Build 3490
Build 3480
Build 3470
*) Update FFMPEG
*) Bugfix
Build 3460
*) Bugfix Release
*) REST API 1.9.2
Build 3360
Build 3350
Build 3348
Build 3340
Build 3338
Build 3336
EXAMPLE:
http://localhost/rest/startRescan.view?u=admin&p=admin&v=1.9.0&c=WebScript
http://localhost/rest/scanstatus.view?u=admin&p=admin&v=1.9.0&c=WebScript
<subsonic-response xmlns="http://subsonic.org/restapi" status="ok" version="1.9.0">
<Scan>
<Status started="false"></Status>
</Scan>
</subsonic-response>Code: Select all
<Scan>
<Status started="true" count="1052"></Status>
</Scan>
</subsonic-response>Build 3320
Build 3312
Build 3310
Build 3306
Build 3304
Build 3300 Beta3
Build 3292
Build 3290
Build 3288SE
Build 3288
Build 3280
Build 3220
Build 3218
Build 3216
Build 3210SE
Build 3210
Build 3206
Build 3204
Build 3200
Build 3158
Build 3155
Build 3154
- madsonic_multi.tag
- madsonic_artist.tag
- madsonic_album.tag
- madsonic_set.tag
- madsonic_dir.tag
Build 3146
Build 3132SE
Build 3132
Build 3130SE
Build 3130
Build 3124
NEW: Code Cleanup
Build 3120
Build 3112
Build 3110
Build 3106
Build 3102
Build 3100
FIX: some GUI Fixes
Build 3098
Build 3092
Backlog
UPDATE: Statistics
Changelog 4.6
Build 2625
FIXED: Code Cleanup
Backlog
