Java Error after moving PC to different lacation
LB66
Unread post by LB66 »
I just move to a new location and all of sudden am getting following error: Any help is appreciated
Message PreparedStatementCallback; SQL [select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type in (?,?) and lower(genre)=? and present and folder in (select path from music_folder where id in (select music_folder_id from user_group_access where user_group_id=? and enabled)) limit ? offset ?]; java.lang.OutOfMemoryError: Java heap space; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: Java heap space
Java version Oracle Corporation 1.8.0_25
Operating system Windows 8 6.2
Server jetty/8.y.z-SNAPSHOT
Memory Used 27 of 310 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank from media_file where type in (?,?) and lower(genre)=? and present and folder in (select path from music_folder where id in (select music_folder_id from user_group_access where user_group_id=? and enabled)) limit ? offset ?]; java.lang.OutOfMemoryError: Java heap space; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: Java heap space at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:106) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:72) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:80) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:605) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:639) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:668) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:676) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:716) at org.madsonic.dao.AbstractDao.query(AbstractDao.java:91) at org.madsonic.dao.MediaFileDao.getArtistsByGenre(MediaFileDao.java:475) at org.madsonic.service.MediaFileService.getArtistsByGenre(MediaFileService.java:553) at org.madsonic.controller.GenresController.getArtistsByGenre(GenresController.java:186) at org.madsonic.controller.GenresController.handleRequestInternal(GenresController.java:155) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:844) at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829) at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:684) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1496) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:154) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:50) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:106) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342) at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1484) at org.madsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:49) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1484) at org.madsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:60) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1484) at org.madsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1476) at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:501) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137) at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:557) at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1086) at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:429) at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193) at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1020) at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135) at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116) at org.eclipse.jetty.server.Server.handle(Server.java:370) at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:494) at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:971) at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1033) at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:644) at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235) at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82) at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:696) at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:53) at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608) at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543) at java.lang.Thread.run(Unknown Source) Caused by: java.sql.SQLException: java.lang.OutOfMemoryError: Java heap space at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source) at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source) at org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(Unknown Source) at org.hsqldb.jdbc.JDBCPreparedStatement.executeQuery(Unknown Source) at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:589) ... 82 more Caused by: org.hsqldb.HsqlException: java.lang.OutOfMemoryError: Java heap space at org.hsqldb.error.Error.error(Unknown Source) at org.hsqldb.persist.DataFileCache.getFromFile(Unknown Source) at org.hsqldb.persist.DataFileCache.get(Unknown Source) at org.hsqldb.persist.RowStoreAVLDisk.get(Unknown Source) at org.hsqldb.index.NodeAVLDisk.findNode(Unknown Source) at org.hsqldb.index.NodeAVLDisk.getLeft(Unknown Source) at org.hsqldb.index.IndexAVL.next(Unknown Source) at org.hsqldb.index.IndexAVL.next(Unknown Source) at org.hsqldb.index.IndexAVL$IndexRowIterator.getNextRow(Unknown Source) at org.hsqldb.RangeVariable$RangeIteratorMain.findNext(Unknown Source) at org.hsqldb.RangeVariable$RangeIteratorMain.next(Unknown Source) at org.hsqldb.QuerySpecification.buildResult(Unknown Source) at org.hsqldb.QuerySpecification.getSingleResult(Unknown Source) at org.hsqldb.QuerySpecification.getResult(Unknown Source) at org.hsqldb.StatementQuery.getResult(Unknown Source) at org.hsqldb.StatementDMQL.execute(Unknown Source) at org.hsqldb.Session.executeCompiledStatement(Unknown Source) at org.hsqldb.Session.execute(Unknown Source) ... 86 more Caused by: java.lang.OutOfMemoryError: Java heap space
DoCC
Has thanked: 40 times
Been thanked: 65 times
Re: Java Error after moving PC to different lacation
Unread post by DoCC »
your database is fucked up, completely.
killall java and madsonic processes , rename the db folder.
start from scratch
LB66
I could see this much ;) but redoing whole thing is what I wanted to avoid with modified theme, all the users etc. Thankfully while ago when I set it up and finished all I did a full backup (of which I forgot with Christmas Holidays etc.) and restore sorted all I just had to run scan for new file But thanks for advise DoCC :) It might come to that one day.
LB66
depending on the installation of Madsonic and operating system, there are several solutions to increase used memory to avoid Java heap size errors (OutOfMemoryError)
Linux standalone
--> madsonic.sh
Windows standalone
--> madsonic.bat
Deb installer
--> /etc/default/madsonic
rpm installer
--> /etc/sysconfig/madsonic
OSX installer
--> /Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub
Windows Installer
nelgin
Been thanked: 14 times
Unread post by nelgin »
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
32127 madsonic  20   0 4841652 1.263g   6376 S 257.5 35.3  69:51.79 java
I think there's something wrong for it to take so much memory and cpu. What would you say is an acceptable size for MADSONIC_INIT_MEMORY and MADSONIC_MAX_MEMORY? I have 350/1024. This used to be fine for me on the 5.x but it's happening on 6.x for me.
