[solved] 5420 + charset encoding
Posted: 10 Jan 2015, 13:36
Hi Mad ,
Are you able to handle this crap ? : P
i use some stuff like this :
Maybe there is a chance to get this working in coming version ?
if ( !function_exists('mb_detect_encoding') ) {
function mb_detect_encoding ($string, $enc=null, $ret=null) {
static $enclist = array(
'UTF-8', 'ASCII',
'ISO-8859-1', 'ISO-8859-2', 'ISO-8859-3', 'ISO-8859-4', 'ISO-8859-5',
'ISO-8859-6', 'ISO-8859-7', 'ISO-8859-8', 'ISO-8859-9', 'ISO-8859-10',
'ISO-8859-13', 'ISO-8859-14', 'ISO-8859-15', 'ISO-8859-16',
'Windows-1251', 'Windows-1252', 'Windows-1254',
$result = false;
foreach ($enclist as $item) {
$sample = iconv($item, $item, $string);
if (md5($sample) == md5($string)) {
if ($ret === NULL) { $result = $item; } else { $result = true; }
break;
return $result;
function str_to_utf8 ($str) {
if (mb_detect_encoding($str, 'UTF-8', true) === false) {
$str = utf8_encode($str);
return $str;
