Hi folks,
if you have a fresh installed x64 linux server and you are willing to install madsonic ,
you might encounter a problem with wma not being played.
This is due to the buildin liblamemp3 in ffmpeg that needs a x86 libncurses.so.5
so just install the x86 lib32ncurses5
and all will be fine...
please don't create a symlink from the x64 to the x86 lib. this will not work
