Madsonic doens't start anymore after upgrading on OSX
Posted: 15 Dec 2014, 18:06
For some reason Madsonic doens't start anymore after upgrading 5.2 Beta2.
How to troubleshoot?
.ılılı. Madsonic Music Streamer .ılılı.
https://support.madsonic.org/
I wish also such a Mac for testing, but need to test it all even virtually.skopo wrote:
- used operating system: OSX 10.10.1
- used CPU architecture: i5 sandybridge x64
- used server memory: old one 64.4 MB / 81.1 MB
- used Java version: Java 7. update 71
- Madsonic Build before: 5.0.3830
- Madsonic Build upgrade to: 5.2 Beta2
- Error messages: N/A just doens't start. no process
- Log entries: How to find on osx?
I think that might cause the problem.Maybe the new Madsonic starter script doesn't work right on Yosemite.
Did you use the new OSX installer?skopo wrote:I think that might cause the problem.Maybe the new Madsonic starter script doesn't work right on Yosemite.
But problem remains with my older mac on work that runs 10.9.4. (test bench for everything. Should be re-installed from very beginning)
I have tried to get standalone running but problem remains the same (even with older builds) it just won't start.
cd /Applications/Madsonic.app/Contents/Resources/Java/
java -cp madsonic-booter.jar org.madsonic.booter.Main -mac
Dez 15, 2014 7:47:04 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@67abaab: display name [org.springframework.context.support.ClassPathXmlApplicationContext@67abaab]; startup date [Mon Dec 15 19:47:04 CET 2014]; root of context hierarchy
Dez 15, 2014 7:47:04 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from class path resource [applicationContext-mac.xml]
Dez 15, 2014 7:47:04 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@67abaab]: org.springframework.beans.factory.support.DefaultListableBeanFactory@4a8acc0c
Dez 15, 2014 7:47:04 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@4a8acc0c: defining beans [deployer,frame,controller]; root of factory hierarchy
Using WAR file: /Applications/Madsonic.app/Contents/Resources/Java/madsonic.war
Extracting webapp to /Library/Application Support/Madsonic/jetty/5420
2014-12-15 19:47:04.651:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2014-12-15 19:47:07.831:INFO:/:Initializing Spring root WebApplicationContext
Dez 15, 2014 7:47:07 PM org.springframework.web.context.ContextLoader initWebApplicationContext
INFO: Root WebApplicationContext: initialization started
Dez 15, 2014 7:47:07 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing Root WebApplicationContext: startup date [Mon Dec 15 19:47:07 CET 2014]; root of context hierarchy
Dez 15, 2014 7:47:08 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
INFO: Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
Dez 15, 2014 7:47:08 PM org.springframework.security.config.SecurityNamespaceHandler <init>
INFO: Spring Security 'config' module version is 3.2.5.RELEASE
Dez 15, 2014 7:47:08 PM org.springframework.security.config.http.FilterInvocationSecurityMetadataSourceParser parseInterceptUrlsForFilterInvocationRequestMap
INFO: Creating access control expression attribute 'permitAll' for /**
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/madsonic/booter/Main : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)Code: Select all
echo export "JAVA_HOME=\$(/usr/libexec/java_home)" >> ~/.bash_profile
echo $JAVA_HOME
/Library/Java/JavaVirtualMachines/jdk1.7.0_72.jdk/Contents/HomeCode: Select all
java -version
java version "1.7.0_72"
Java(TM) SE Runtime Environment (build 1.7.0_72-b14)
Java HotSpot(TM) 64-Bit Server VM (build 24.72-b04, mixed mode)
