multiple network interfaces
Posted: 17 Nov 2014, 20:29
Hi !
I'm on Ubuntu 14.04LTS server edition.
I've been running madsonic for a long time, and it is becoming better and better.
Thanks MadEvil !
Recently, I have installed openvpn, which works fine. I had to put some iptables rules on the hosted subsonic server in order to make it work.
The problem is that when I'm on my local network, I can't access my madsonic interface (xxxxxx.subsonic.org), it tries to access via the tun0 IP (the one for the vpn) instead of eth0 (my real local ip). The only workaround is to put the local address 192.x.x.x:4040. From outside the local network, it works perfectly fine.
Have you any idea of a rule I can add in iptables to change this behaviour ?
Here is my iptables config (generated via webmin) :
I must also add that the dhcp server is not on the same machine, that's why all traffic is opened, i have a firewall on the dhcp server, where I changed nothing (except a rule to authorise openvpn).
# Generated by iptables-save v1.4.21 on Mon Nov 3 18:49:42 2014
*nat
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
-A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE
COMMIT
# Completed on Mon Nov 3 18:49:42 2014
*mangle
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
-A INPUT -j ACCEPT
-A INPUT -i eth0 -j ACCEPT
-A INPUT -i tun0 -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -p tcp -m tcp --dport 10000 -j ACCEPT
-A INPUT -p udp -m udp --dport 1194 -j ACCEPT
-A FORWARD -i tun0 -j ACCEPT
COMMIT
