SNI support
jimyx17
SNI support
Unread post by jimyx17 »
Hi guys,
Few days ago I started using Madsonic Android client, but face a barrier because my sever uses SNI in order to handle virtualhosts, which is not supported by the client.
You can find attached a fix to this problem, ¿would you mind to include this fix or any other that you prefer in order to include SNI support in future versions?
Thank you for your hard work.
SNI.txt
SNI Patch
(5.43 KiB) Downloaded 885 times
Re: SNI support
Sure can this be added, can you imagine getting other problems caused by this change?
jimyx17
Re: SNI support
Not really,
I'm running further test with devices under api 16. I'll let you know if I find something.
Thank you!
Re: SNI support
Update repository & pushed beta version 5.6.303 to the google play store.
If you are a early adopter you will get the update automatically.
Link Github https://github.com/MadMarty/madsonic-5.6/commits/master
Link to early adopter registration http://forum.madsonic.org/viewtopic.php?f=18&t=870
