Simple start/stop for stand alone version
Posted: 22 Jun 2014, 11:00
I don't know if may be of some interest, but in case these are the scripts i use to start/stop MS from the desktop:
Assuming your ms standalone folder is in /var/madsonic
start:
right click on the desktop - create new empty document - open it with a text editor, than past
stop:
right click on the desktop - new file - open with a txt editor, than past
save and close, rename it in Madsonic_stop (or what you prefer) than from terminal give:
cd Desktop
sudo chmod +x Madsonic_stop
In this way you can start/stop ms with a click from your Desk.
Hope this will be of some help
start:
save the file and rename it in "Madsonic start", or what you prefer;[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=OFF
Name[C]=Madsonic
Icon=/path/to/preferred/icon (NOTE: in my case this don't works with ms, dunno why)
Exec=sudo /var/madsonic/madsonic.sh
Comment[C]=
stop:
#!/bin/sh
sudo killall javacd Desktop
