Does the Android client support Lyrics? [Solved]
Posted: 01 May 2014, 15:47
by apastuszak
If it does, how do I get them to work? A lot of my MP3s have embedded lyrics in them.
Re: Does the Android client support Lyrics?
Posted: 13 May 2014, 16:21
by JoeDat
Bump.
Says in the release notes for the 5.5 version of the Android client that it supports a serverside lyric API...does that imply the client can display lyrics? I can't figure out how if so.
Posted: 14 May 2014, 02:36
by JoeDat
Got it figured out. In case anyone else is looking....
3 vertical dot icon next to a song in your playlist. It's on the trimmed down view of the song (if you see album art, you're in the wrong view.) If there is an official term for this view, please let me know. I'll gladly edit this post to clean it up.
