http://www.kurioworld.com/k/us/parents/products/10s/
Seems like it should be able to run the player. I purchased the player through Play store. Play store says it's not compatible... Although I bet it will work perfectly fine. What has to change to make it possible? Or what info do you need from this device to make it possible …?
Android 4.2 operating system (Jellybean) 10.1" 1280 x 800 pixel high resolution IPS multi-point touchscreen Powerful Quad Core processor with dedicated 3D graphics chip, 1 GB RAM 8GB integrated memory, extendable up to 40GB with Micro SD Card Wi-Fi: Built-in Wi-Fi, 802.11 b/g/n 2 front stereo speakersForward & rear facing cameras: 2.1 megapixel front / 2.1 megapixel back HD video player, music player, E-book reader, microphone Micro USB high speed transmission charger and host for external storage & peripherals connection Micro HDMI connection for HD 2160p playback on TV Video: H.264, H.263, VC-1, MPEG-1,2,4, DIVX-3,4,5,6, XVID, H263, WMV7/8, VP6, AVS Music format: MP3, WMA, OGG, FLAC, APE, AAC, AC3, ATRA, DTS Photo format: JPEG, BMP, GIF, PNG E-book format: EPUB, PDF Recording format: MP4 Language: supports multiple languages Supported computer systems: Windows2K/XP/Vista/7/8/Linux2.4/Mac OS 10.4High Capacity Lithium Polymer 7000mAh-3.7V Battery Micro SD Card Slot (card not included) 3.5 mm Headphone Jack + Mic pin to support a headset with a microphone Silicone Bumper Included Included in the box : Kurio 10S Tablet, Protective Silicone Bumper, Micro USB adapter, Micro USB cable, Power Adapter
