Any idea how I might fix this? Logfile is attached, but here are the first few lines
[2014-04-10 09:28:44,410] INFO DaoHelper - Checking database schema.
[2014-04-10 09:29:39,806] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\madsonic/db/subsonic.backup java.io.EOFException: Unexpected end of ZLIB input stream
Failed to Initialize database
Re: Failed to Initialize database
it looks like you have a corrupted database file, try to stop the Madsonic Service, delete the c:\madsonic\db folder (to restart DB from scratch)
and restart your service. A new Database will be created automatically.
Sure - make a back up BEFORE it crashes.
Just make a regular archive copy of the C:\Madsonic directory so you have a recent backup. You can manually copy once in a while, or if you're on Windoze you can use SyncToy to make automated backups. If you do the automated route, just be sure to occasionally back up one of the backups so that the process doesn't just blindly overwrite a good backup with a new "crashed" copy.
Synctoy wasn't working for me, not enough control.
Here's my attempt at a backup batch file. If you're interested I can send the called batch files as well.
@echo off
set appver=1.1
:: Check for new version on the server, move it local if updated
call checkbat MadSonicBackup
echo .
echo %0 Ver 1.0
if (%debug%)==(on) set debug=on
if /i (%1)==(/w) echo Force Weekly
:: Backup Drive
set dest=R:
:: every tried to break out of process that doesn't ask for keyboard input?
set break on
:: Time the backup. A backup time that is out of whack indicates a problem
call elapsedtime /start
call Logger MadSonic Backup Started
:: Determine which day it is. Daily backups have their own folder
call dow.bat
set wkly=Sun
:: Are we forcing a weekly backup?
if /i (%1)==(/w) set wkly=%dow%
echo %wkly%
if /i (%debug%)==(on) pause
echo Backing up for %dow%
echo stopping MadSonic service
"c:\madsonic\madsonic-service.exe" -stop
echo Madsonic Service Stopped
if (%dow%)==(%wkly%) echo Backup for %dow% is Weekly (%wkly%)
if not (%dow%)==(%wkly%) echo Backup for %dow% is Daily (weekly is %wkly%)
echo .
:next1
:: Make folders if they don't exist
if not exist R:\backups\Madsonicbackup\*.* md R:\backups\Madsonicbackup
if not exist R:\backups\madsonicbackup\%computername%\*.* md R:\backups\madsonicbackup\%computername%
if not exist R:\backups\madsonicbackup\%computername%\daily\*.* md R:\backups\madsonicbackup\%computername%\daily
if not exist R:\backups\madsonicbackup\%computername%\weekly_%wkly%\*.* md R:\backups\madsonicbackup\%computername%\weekly_%wkly%
:: Variable dest is where the backups will go
set dest=R:\backups\madsonicbackup\%computername%\daily
set msg=Madsonic Backup Finished
if (%1)==(/t) set msg=TEST %msg%
if (%dow%)==(%wkly%) set dest=R:\backups\madsonicbackup\%computername%\weekly_%wkly%
if (%dow%)==(%wkly%) set msg=Madsonic Weekly Backup on %dow% Finished
if not (%dow%)==(%wkly%) echo Doing daily Backup to %dest%
if (%dow%)==(%wkly%) echo Doing Weekly Backup to %dest%
Echo Some quick Housekeeping
echo Backing up to: %dest%
echo Cleaning DB folder
if not (%dow%) == (Fri) goto noclean
del %dest%\db\*.* /s /f /q > nul
echo Cleaning Jetty Folder
del %dest%\jetty\*.* /s /f /q > nul
echo Cleaning Lucene Folder
del %dest%\lucene\*.* /s /f /q > nul
echo Cleaning Main Folder
del %dest%\*.* /f /q > nul
:noclean
set break=on
echo Copying MadSonic files to %dest%
call Logger "%msg%" %dest%
echo on
del %dest%\db\*.* /f /Q
dir c:\madsonic
echo Backing up to: %dest%, This will take a while
echo .
xcopy c:\madsonic\*.* %dest% /Y /d /s > nul
:: Clean up the Podcast folder, we don't need to keep that
del %dest%\podcasts\*.mp3 /f /Q
echo off
call elapsedtime /stop
call Logger Ended: "%msg%" %dest% " Total Elapsedtime: "%elapsed%
sleep 5
if exist %dest%\tmp*.txt del %dest%\tmp*.txt /f
:: We call Filestamp so folders will show they have been updated
call filestamp R:\backups\madsonicbackup\%computername%\
:: All good - restart
c:\madsonic\madsonic-service.exe -start
:next2
if (%1)==(/t) echo Backup to %dest%
:: We should email the log here....but we haven't yet
@echo off
set appver=1.1
echo .
echo %0 Ver 1.0
:: Backup Drive
set dest=R:
set break on
call dow.bat
set wkly=Sun
echo %wkly%
echo .
:next1
:noclean
set break=on
echo on
dir c:\madsonic
echo .
echo off
sleep 5
:next2
Thank you,
Nice job. Personally, I don't run into db failures very often and I run several Subsonic/Madsonic instances in parallel in multiple VM's, but your efforts here are much appreciated. This seems to be a common issue in the forums. I don't know why, other than factors that might turn the host machine off without giving the db time to close out the files properly. Could be related to drive caches not flushing prior to shutdown or something along those lines.
In any event, I'm sure that many Windows users might find this a valuable way to be prepared.
Thanks. BTW, I noticed a bug where I used the subfolder named ...\daily where I should have used ...\%dow%. I could have gone with son, father, grandfather, but this was easier.
I've attached the updated file here. If anyone is interested, let me know and I can supply the supporting files.
- Attachments
MadSonicBackup.rar- (1.2 KiB) Downloaded 468 times
