Remove Login + CDN Support
Posted: 18 Mar 2014, 19:54
Is there any way to remove the login system for Madsonic? I'd love to open up my madsonic publicly.
Also, is there a way to make a CDN work on streaming music?
I'd like to point it to maxcdn (CDN Mirror) and stream music using the cdn. Can you please tell me what file in subsonic's source code do I need to edit to achieve this? I just need to replace the url, to (cdn.mymadsonic.url/some.mp3)
Any guidance would be very much appreciated. Thanks!
