It looks like the client had detected the server incorrectly.zer0squared wrote:You're right. I don't even know what REST or API means, even after browsing that page of code. I'm not trying to re/write a program - I just want to use Madsonic (instead of Subsonic) to stream my media when I'm away from home. Is there something in the settings that we need to un/check to get it working again?Madevil wrote:@jsgates @zer0squared your concern shows me that there is need for explanation for the use of the REST API
only the Subsonic REST emulation is a Premium feature, the Madsonic REST 2.0 API is free!
Read more here: http://beta.madsonic.org/pages/api.jsp
Thanks for the reply!
Try to add a new server entry on your Madsonic Client to generate a new server profile,
ff that also does not help clean and reinstall the Madsonic client on your phone.
