Create Playlist Workflow
newburns
Been thanked: 10 times
Unread post by newburns »
Once you click create Playlist (wherever it will be located), it should pop up the playlist edit screen. It should not automatically name it, and force you to go to show more, playlist, playlist name, and then edit.
Also, administrators should be able to see all playlists.
These users thanked the author newburns for the post (total 2):
MadsonicDrAlban
Rating: 15.38%
megamorf
Re: Create Playlist Workflow
Unread post by megamorf »
I have to agree. It's a pain to create a playlist when you are only able to give it a name after it has been created.
+1
These users thanked the author megamorf for the post (total 2):
DrAlbannewburns
Rating: 15.38%
newburns
Am I the only one that wants this?
Maybe I should attempt to tackle myself? I only know PHP coding, what is MadSonic written in?
newburns
Any roadmap on creating playlist workflow? Right now it is a pain to create a playlist, then some extra clicks to edit the name.
Even the possibility to name the playlist immediately after creation would be fine (Of course with the Public checkbox as well).
Tamps
Unread post by Tamps »
And allso I miss "save" button.
Everytime when I load a playlist and adding new tracks to it and I like to save the playlist then everytime we need to great a new playlist. and go to playlist section and delete old one, also need to name it and so on.. there should be a button to just save current playlist what was previusly saved..
addseo1115
Unread post by addseo1115 »
