When will the Android app be available on google play store
Any idea when this will be available
I have paid for Madsonic pro app and reset my phone and now i cant use madsonic since it was removed from the google play store.
Re: When will new app be available
The improved Android app will be released in the next few weeks. Development and tests are already at high gear.
- These users thanked the author Madsonic for the post (total 3):
- kmil992000 • daemon9th • fumiman
- Rating: 23.08%
- Been thanked: 2 times
I would also very much appreciate better android auto integration!
- These users thanked the author yougotborked for the post (total 2):
- Madsonic • ChatNoir
- Rating: 15.38%
Re: When will the Android app be available on google play store
any update on the new version...
i personally do not care when you release the next version but for some reason you decided to remove the old app from the app store and i since i have a new phone i have no way of installing any madsonic app.... any updates at all?
Hello
I have changed phones for some time and can not find the madsonic version for android, or can I find a link to reinstall it?
thank you for the answer
Chris
Chris
Yup same with me... It's okay you take your time and work as long as you want on the new version of the app but why take the perfectly working version off of Google if you don't have a replacement ready?
- kmil992000
- Has thanked: 17 times
- Been thanked: 5 times
Hi Madsonic Team,
Any update? Nearly 3 months since your last update now and still no sign of the new client app.
I paid for a subscription that included 2 licences for the client, yet I've never been able to redeem them as the app was removed from Google Play before I got a chance to download it, so I'm feeling a little short-changed here.
If the client is still not ready for full Google Play release, is there any chance of an alpha or beta apk version we can side-load to help with testing in the meantime? The screenshots look great btw and I'm looking forward to it being even better than DSub that I'm having to use instead at the moment.
Kev
Is there an update on this? I just got a new phone and I need to download the app again.
I would love to get a beta version of the new 7.x app but I can't even find the old version on the play store anymore.
What exactly am I suppose to do? I guess I could look at side loading the old version from some third party site but that isn't a very good solution.
What are my options for officially getting an apk?
- These users thanked the author Catsrules for the post:
- ombra040683
I need some help....
What client can i use for the android?
I have tested a lot of programs and no works...
Also i wanted to have the capacity to use offline mode and download to my mobile phone musics or albums that i choose.
Can you help me
Can you help me
I've been trying to find out the Madsonic app in the Play store..but there is not something like that in the play store. how should I search to download Madsonic on my Android?
I don't use Madsonic these days (airsonic-advanced on Linux with DSub for Android) since it's basically dead and the developper has never been great at communicating openly/regularly but for those who still want to use the old Madsonic apps, I saved two versions before they were pulled off from the Play Store.
I hosted them on Mega for you. 6.0.4 was the latest version and isn't guaranteed to work right on recent Android versions, use at your own risk.
I haven't tested the apps on Android 9,10 and 11, I just don't use Madsonic anymore.
- Version 5.7.1 (non pro), made for Android 5.0, with Android 4.0.1 as a minimum requirement -> https://mega.nz/file/jHwwgYIZ#BtdXjcieQwz-DsqQiANaCSLVaH9_-5SXQ3bAKaMeEuc
- Version 6.0.4 (pro I think), made for Android 6.0, with Android 4.1 as a minimum requirement -> https://mega.nz/file/KTpy3axD#Hd3lnSTx6XDVdP-LKJVYBXWDomXsWljOTBFpB75VJfc
