VERSION: Server 7.0.10390.a6fd24b.20190510.0829
SERVLET: JETTY
SERVER: CPU: Core i3-6100 | ARCH: x64 | MEMORY: 16GB
OS: WINDOWS 2012 R2 | WINDOWS 10 | DEBIAN 8.1 | FREBSD 9.1 | OSX | OTHER
SYSTEM: Ubuntu 18.04 LTS Server
INSTALLER: DEB
JAVA: OpenJDK 11.0.3
DESCRIPTION: See below
REPRODUCIBLE: YES
LOGGING: No Logentry created (Loglevel: "DEBUG")
Clicked "Settings" -> "Media Tools" -> "Normal Rescan"
What Happened:
I got the following Error Message (Replaced Usernames with "<UsernName>").
Exception java.io.FileNotFoundException
Message /var/media/playlists/backup/Various Artists - <UsernName> - 09.05.2019, 17-49.m3u8 (No such file or directory)
Java version Oracle Corporation 11.0.3
Operating system Linux 4.15.0-52-generic
Server jetty/9.4.z-SNAPSHOT
Memory Used 138 of 260 MB
Stack trace java.io.FileNotFoundException: /var/media/playlists/backup/Various Artists - <UsernName> - 09.05.2019, 17-49.m3u8 (No such file or directory)
at java.base/java.io.FileOutputStream.open0(Native Method)
at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
at java.base/java.io.FileOutputStream.(FileOutputStream.java:237)
at java.base/java.io.FileOutputStream.(FileOutputStream.java:126)
at java.base/java.io.FileWriter.(FileWriter.java:66)
at org.madsonic.service.PlaylistService.backupAllPlaylists(PlaylistService.java:303)
at org.madsonic.controller.CleanupSettingsController.handleRequestInternal(CleanupSettingsController.java:127)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1623)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1610)
at org.madsonic.filter.MetricsFilter.doFilter(MetricsFilter.java:54)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:753)
at org.eclipse.jetty.server.Server.handle(Server.java:505)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:427)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:321)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:159)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804)
at java.base/java.lang.Thread.run(Thread.java:834)
Created: 2019-05-09 17:49:54.161
Changed: 2019-06-25 03:01:05.123
Found these two Logentries wich have a corresponding Timestamp:
[25.06.19, 03:01] INFO PlaylistService Starting playlist import.
[25.06.19, 03:01] INFO PlaylistService Completed playlist import.
Last automatic Folder Scan: 2019-06-25 03:00 -> Was successful
Further Investigating:
Listed all Playlist Elements: "SELECT * FROM media_file WHERE ID in (SELECT media_file_id FROM playlist_file WHERE playlist_id = 1)"
Checked if all Files Exist with "find" Command on Server -> They do
Checked if File "/var/media/playlists/backup/Various Artists - <UsernName> - 09.05.2019, 17-49.m3u8" exist -> No, even the folder "/var/media/" does not exist, but other Playlists don't throw errors -> Might be a virtualised Folder?
So, what can I do know?
Greetings Kae
