REPRODUCIBLE: Yes, but not everytimes.
I get a
But not with all the letters from the index.org.springframework.dao.DuplicateKeyException
Some of the letters do work, but I see strange "holes" in the list. Are those (holes) "normal"? I've never seen them before. What could be a reason ?
Exception org.springframework.dao.DuplicateKeyException
Message PreparedStatementCallback; SQL [update media_file set folder=?,type=?,override=?,format=?,data=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,genre_raw=?,mood=?,mood_raw=?,bpm=?,composer=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=?, rank=?, custom=?, popular=? where path=?]; integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM
Java version Oracle Corporation 1.8.0_172
Operating system Linux 3.10.102
Server jetty/8.y.z-SNAPSHOT
Memory Used 235 of 899 MB
Stack trace org.springframework.dao.DuplicateKeyException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,override=?,format=?,data=?,title=?,album=?,album_name=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,genre_raw=?,mood=?,mood_raw=?,bpm=?,composer=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=?, rank=?, custom=?, popular=? where path=?]; integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:245)
at org.madsonic.dao.AbstractDao.update(AbstractDao.java:82)
at org.madsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:278)
at org.madsonic.service.MediaFileService.checkLastModified(MediaFileService.java:228)
at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:338)
at org.madsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:314)
at org.madsonic.controller.MainController.handleRequestInternal(MainController.java:120)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM
... 78 more
Caused by: org.hsqldb.HsqlException: integrity constraint violation: unique constraint or index violation: IDX_MEDIA_FILE_CUSTOM
at org.hsqldb.index.IndexAVL.insert(Unknown Source)
at org.hsqldb.persist.RowStoreAVL.indexRow(Unknown Source)
at org.hsqldb.persist.RowStoreAVLDisk.indexRow(Unknown Source)
at org.hsqldb.TransactionManager2PL.addInsertAction(Unknown Source)
at org.hsqldb.Session.addInsertAction(Unknown Source)
at org.hsqldb.Table.insertSingleRow(Unknown Source)
at org.hsqldb.StatementDML.update(Unknown Source)
at org.hsqldb.StatementDML.executeUpdateStatement(Unknown Source)
at org.hsqldb.StatementDML.getResult(Unknown Source)
... 83 more
next try
Error
Memory Used 174 of 896 MB
... 78 more
... 83 more
