Madsonic service running but that's it
zzzonedotnet
Has thanked: 6 times
Been thanked: 10 times
Unread post by zzzonedotnet » 20 Oct 2017, 01:36
I attempted to reinstall the beta for 6.3 from a stable version running on Windows 10. When I installed it the control panel said that it was running but I could not open the web control. Nothing happened at all. The browser didn't even open.
So I uninstalled it and reinstalled the stable 6.2 version. Unfortunately, I got the same result. I then uninstalled that version.
I restored my registry and and then reinstalled the stable 6.2 version.
Now, the web control opens the browser but I get a 503 error and nothing displays.
What should I try next besides wiping the computer and starting over completely?
I have a Premium subscription.
Thanks.
Tak-MK
Has thanked: 7 times
Been thanked: 15 times
Re: Madsonic service running but that's it
Unread post by Tak-MK » 20 Oct 2017, 09:06
I had that problem, more or less, because of this bug --> http://forum.madsonic.org/viewtopic.php?f=63&t=2379
Try using the last beta version just for check :/
These users thanked the author Tak-MK for the post:
zzzonedotnet
Has thanked: 1118 times
Been thanked: 434 times
Unread post by Madsonic » 20 Oct 2017, 11:48
Try to complete uninstall Madsonic and start from scratch:
[*] stop madsonic server
[*] uninstall madsonic
[*] delete folder c:\madsonic or /var/madsonic
[*] cleanup all Browser Caches
[*] cleanup all temp files
Info about used folders: http://beta.madsonic.org/pages/installation.jsp#general
After reinstall/restart the Madsonic service, a new database will be automatically created in the folder %MADSONIC_PATH%\db
Best rergards,
zzzonedotnet
zzzonedotnet
Unread post by zzzonedotnet » 20 Oct 2017, 11:57
So I installed the latest stable version of 6.2 and the web interface loads now.
It scanned my music and created a database.
The only problem now is that no cover art displays. Every cover displays as a black/blank square in the web interface in Chrome and in Firefox.
Any other thoughts?
Thanks.
Unread post by Madsonic » 20 Oct 2017, 16:24
please retry with the latest 6.3 build, send you email with information.
zzzonedotnet
zzzonedotnet
Unread post by zzzonedotnet » 20 Oct 2017, 23:41
Madevil wrote:please retry with the latest 6.3 build, send you email with information.
Thank you. I will try. Did you say you were sending an email? I haven't gotten one.
zzzonedotnet
Unread post by zzzonedotnet » 21 Oct 2017, 00:28
WOOT.
I scrubbed the old install and all the OS and browser caches.
I installed the latest 6.3 build and was successful in that it is scanning my music (400k files) right now.
I'll let you know what happens.
zzzonedotnet
Unread post by zzzonedotnet » 21 Oct 2017, 13:47
zzzonedotnet wrote:WOOT.
The first scan didn't work too well, got only about 25% of my music.
But I rescanned and that seems to have done the trick.
18,977 artists
39,868 albums
1,050 genres
17 moods
372,845 songs
48 videos
10 podcasts
22 audiobooks
9572.07 GB (~ 33,847 hours)
zzzonedotnet
Unread post by zzzonedotnet » 22 Oct 2017, 20:18
Well. I've been testing it pretty extensively and it looks and feels good.
Best news: it's scanning tags now, I think.
Searches should be much more accurate if the music is tagged correctly.
Someone correct me if I am wrong.
Tak-MK
Unread post by Tak-MK » 23 Oct 2017, 09:01
How much time did it spent to scan 400k files? I have to wait a long time to scan 200k, like ten minutes or so if it's a rescan, and like an hour if it's the first scan :(
zzzonedotnet
Unread post by zzzonedotnet » 28 Oct 2017, 23:23
Tak-MK wrote:How much time did it spent to scan 400k files? I have to wait a long time to scan 200k, like ten minutes or so if it's a rescan, and like an hour if it's the first scan :(
A full scan took several hours: honestly I didn't time it.
A rescan takes about 30 mins.
Unread post by Madsonic » 29 Oct 2017, 10:07
Since version 6.3, more metadata is being read out, which will take much more time for the initial scan, all other scans will consume much less time.
Go to Settings > Admin Panel and configure the scan mode to NATIVE which is much faster than the MIXED mode.
