Madsonic Docker support
opty
Re: Madsonic Docker support
Unread post by opty »
first of all thanks for the Docker image, it was real easy and simple to set it up on my synology NAS.
i actually for the first time was able to stream video to isub using this latest image but i also noticed that the url of the streams are exposed and anyone can actually stream any file by guessing the stream ID and without login.
is this something on my setup or some permission not being set correctly on madsonic side? it seems the madsonic admin account is being used for the stream
thanks
opty
just a little update.
it seems like this is true on any setup and server version and has nothing to do with synology or docker. this happens even on madsonic/subsonic demo site.
one of the reason i noticed this was the extreme number of hits/played on one of my video series on my server over 1500 in matter of days and i only have like 10 user with 3-5 of them being active users!
These users thanked the author opty for the post:
Answers: 3
Has thanked: 1154 times
Been thanked: 450 times
with the new Madsonic 6.1 branch, authentication stream endpoint with token will solve this issue.
http://beta.madsonic.org/pages/changelog.jsp#6.1
opty
opty
This is a real good news! and the 6.1 version already looks promising and slick. it seems like we are moving away from flash. :thumbsup:
adrianp
Unread post by adrianp »
Hi and thanks for working on the Docker support. I had a question regarding the docker images for Unraid. Why are there 4 different ones? And why would I choose one vs another? Just trying to figure out which one I should use. Im currently on Unraid 6.1.9.
Thank you,
Adrian
arckosfr
Unread post by arckosfr »
I currently using one of my docker image for Madsonic, it's based on Alpine.
Advantage is the weight of the image (around 5Mb for alpine).
Complete size (on serveur is 231Mb) and the actual tag on the hub a around 150Mb.
I think proposing an image based on Alpine can be great :)
Link of my image on the hub : arckosfr/madsonic (can't post URL)
Have a good day !
These users thanked the author arckosfr for the post:
daemon9th
Unread post by daemon9th »
Thanks for the great docker images!
Any chance of getting an update to the madsonic/arch-madsonic branch docker similar to the ubuntu and debian based dockers?
br
These users thanked the author daemon9th for the post:
z-vap
Unread post by z-vap »
Hey. I was trying to use containers and thought id give this a try. I have a test openmediavault 3.0 VM that I am trying out and just installed their stable docker plugin. I found the madsonic debian image and started it, and a container showed up. But the container keeps "restarting" over and over.
mkdir: cannot create directory ‘/config/media’: Permission denied
mkdir: cannot create directory ‘/config/playlists’: Permission denied
mkdir: cannot create directory ‘/config/transcode’: Permission denied
cp: cannot stat ‘/var/madsonic/transcode/linux/*’: No such file or directory
/var/madsonic/madsonic.sh: 164: /var/madsonic/madsonic.sh: cannot create /config/madsonic_sh.log: Permission denied
Started Madsonic [PID , /config/madsonic_sh.log]
I don't know if its something I did, or if its the image itself, or what. Any ideas?
VikingOy
Has thanked: 3 times
Unread post by VikingOy »
I'm using a standard Debian Madsonic Image installed in ContainerStation (Docker) on my QNAP TS-453Mini server, and it runs just beautifully.
These users thanked the author VikingOy for the post:
daemon9th
With the new versions coming out for download, any possibility for an update to the docker images in the near future?
I am still using “madsonic/debian-madsonic” (which has been running smoothly for 2 years), but would be great to try the new version 7 out as a docker install (running in Unraid).
