I'm a Subsonic and Sonos user that's evaluating Madsonic. I have a small problem, my multi-discs albums that are in separate folders like this:
artist - album name (CD1)
artist - album name (CD2)
They are catalogued in Madsonic as null - Disk1 and null - Disk2 for the album names.
Thanks for your help.
[Solved] multi-discs albums - null disk
Re: multi-discs albums - null disk
Hi there,lpr wrote:Hello,
some things work different like in subsonic
you have two options to fix this:
1. in Madsonic there is a specific MediaType for Albumsets so .. put your albums in a subfolder and drop the set picture as set.png in this folder. more info: http://forum.madsonic.org/viewtopic.php?f=5&t=19
2. disable Albumset parsing option: Settings -> General -> Enable AlbumSet/Folder Parsing
in both cases you should do a full rescan to force metadata refresh.
Hello Madevil,
Thanks for the quick reply, it's now working great. Since I have you on the line, I'll ask you 2 more quick questions.
My Sonos is not recognizing my login information for Madsonic. I get the following error in the logs: "Failed to enable/disable music service in Sonos controller 192.168.1.12: org.apache.http.client.HttpResponseException: Method Not Allowed"
Also my name.madsonic.org address is not connecting with a ERR_NAME_NOT_RESOLVED.
For both of these problems, I've made sure to disable subsonic so there was no conflict.
Thanks again for your time.
Hi there,lpr wrote:Hello Madevil,
Which Firmware version have your Sonos system? latest --> http://www.sonos.com/software/release/5-4
The domain share function (xxx.madsonic.org) need more backend services which aren't online at the moment, will come later.
Can you please set the Log-level to DEBUG and send me your madsonic.log file?
At the moment Sonos 6.0 is not public and have an NDA,
i found no documentation about interface changes,
but found many issues around this topic.
When its public this can be fixed!
I learned that this is a mandatory point: "drop the set picture as set.png in this folder" and it wont work if the set-folder does not contain album artwork. Would it be a bad idea to change Madsonic so that even folders without album art are considered as album sets? I think the existance of subfolder "CD1" and "CD2" are a clear indicator for an album set even without album art.Madevil wrote: some things work different like in subsonic
Not all album sets have album art and the user would have to create a file "madsonic_set.tag" manually everywhere where album art is missing.
