How do I setup tomcat/madsonic
Re: How do I setup tomcat/madsonic
I hope this little guide help you:
1. Install Tomcat
2. Add an administrative user to Tomcat
Tomcat does have any users defined that could be used for administrative purposes so we need
to open tomcat-users.xml in a text editor and add a user with the proper roles assigned to it.
Replace its content with the following and make sure that you replace USERNAME and PASSWORD with the values you want:
On Linux, Madsonic keeps its files in /var/madsonic. Depending on your configuration, Tomcat may not be permitted to create this directory,
in which case you have to create it manually:
3. Restart Tomcat Service
4. Deploy and administrate
the madsonic.war file can be easy managed within the admin GUI
http://localhost:8080/manager/html
1. Install Tomcat
$ sudo apt-get install tomcat7 tomcat7-common tomcat7-admin
$ sudo nano /etc/tomcat7/tomcat-users.xml
<?xml version='1.0' encoding='utf-8'?>
<tomcat-users>
<role rolename="admin-gui"/>
<role rolename="manager-gui"/>
<user username="USERNAME" password="PASSWORD" roles="manager-gui,admin-gui"/>
</tomcat-users>
$ sudo mkdir /var/madsonic
$ sudo chown tomcat7:tomcat7 /var/madsonic
$ sudo service tomcat7 restart
do you have a /var/subsonic directory? whats in there?justin wrote:this is all i get when i try to start it FAIL - Application at context path /subsonic could not be started
any log file, errors?
Got it Working thanks for your help. after deploying, it copied everything to /var/subsonic like it was suppose to but it must have changed permissions because I had to sudo chown tomcat7:tomcat7 /var/subsonic again then it let me start it.Madevil wrote:do you have a /var/subsonic directory? whats in there?justin wrote:this is all i get when i try to start it FAIL - Application at context path /subsonic could not be started
- Has thanked: 1 time
- Been thanked: 4 times
its possible to run madsonic on same tomcat installation wheres allready running subsonic?
- Been thanked: 2 times
hi is the prozess for madsonic war the same
doe i have to deploy only the madsonic war file ore also the subsonic?
you are right nano is the better choice !aadam12 wrote:@Madevil thanks for the HowTo
FYI: Wherever it says "gedit" please change it to "nano" or "vi"... this is Ubuntu Server there is no GUI.
PS: complete guide updated!
Is anyone else having issues with any of the 6.0 or 6.1 versions deploying in Tomcat?
I'm on a QNAP NAS and am overwriting the .war file with the newer file but it will not deploy.
Do I need to wipe out my 5.1 instance on the server first and then deploy? I swear I've tried that and
it wouldn't install the WAR package as a whole for 6.0 or 6.1.
Thanks.
Thanks.
