thanks for reporting, i will recheck the plugin for the Gotham release.
Just installed new setup on OSX 10.9.4 and XBMC 13.2.muiz wrote:Tried to install in Gotham 13.2 "picture" But it wont start.
Installed just fine. Song problem remains...
Have to stream over FTP (pain in the ass)
Re: Madsonic Server 5.x XBMC Plugins
Wondering if anyone has had any success with last.fm scrobbling yet? I guess I had erroneously thought the Madsonic server would handle last.fm scrobbling, since that seems to work fine for me when using the web interface. Or is that only supported in certain clients? In other words not XBMC?
Anyways I installed the XBMC last.fm plugin (service.scrobbler.lastfm) but that doesn't seem to scrobble either from XBMC's side
On Gotham 13.2. No trouble installing or on playback though
Hi all, same issue than Neilbla
the plugin works well, but it show only the the folders inside the main folder, and not the files....
so, if i share my home/user/video folder, with 5 files and 3 folders, i have access on the 3 folders content, but not at the 5 files, and same for music files.
Is possible to fix that? or we can only move files in new subfolder as workaround?
Tk
Tk
