Hallo, it happens that when I access to the video link on the right frame, it does not open the link at all.
This only happens when all the page is completely loaded (right when the "TOP" list appears) and not when the frame is not completely loaded.
The same issue happens when I search for the title of a video.
In this case the results do not allow access to the video (I mean the link does nothing).
Is there any setting that can fix this?
the behaviour does not depends on madsonic skin and is and on subsonic this does not happens.
Thank you.
Paolo
BY THE WAY: this only happens on admin profile, not on personal profile.
Build 5110 video link does not work
piretro999
- Been thanked: 4 times
- These users thanked the author piretro999 for the post:
piretro999
Re: Build 5110 video link does not work
Hi, I can be more precise: the admin and the user was differing for the configuration of the scroll bar type.
That is the real difference.
If you flag CustomScrollbar Enabled all works fine.
If not, the problem persists.
