Android Client Early Adopter Program
Android Client for Madsonic
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
You can join this program to access madsonic beta version for testing.
Join in https://groups.google.com/forum/?hl=en#!forum/madsonic
Login https://play.google.com/apps/testing/gi ... y.madsonic
These users thanked the author Madsonic for the post (total 5):
chalibocolmike6453GJ51kornkid5622
Rating: 38.46%
nh5
Re: Android Client Early Adopter Program
Unread post by nh5 »
All is well so far no bugs to report however the same issue I've always had still occurs occasionally. If I'm downloading a big media file like a 120MB mp3. Sometimes it will continuously loop when downloading it. Normally playing it while downloading prevents it. But when pinning it to download it occurs pretty commonly. I've had this issue as far back as I can remember. Any idea?
Answers: 4
nh5 wrote:All is well so far no bugs to report however the same issue I've always had still occurs occasionally. If I'm downloading a big media file like a 120MB mp3. Sometimes it will continuously loop when downloading it. Normally playing it while downloading prevents it. But when pinning it to download it occurs pretty commonly. I've had this issue as far back as I can remember. Any idea?
hi there, i will recheck this.
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
Some times Artist-Title is not send over bluetooth.
Weirdly problem is fixed by listening one song in spotify. :D
Clayboy
Unread post by Clayboy »
login url seems like it's down getting an error... to get access to the beta channel
Answers: 4
Clayboy wrote:login url seems like it's down getting an error... to get access to the beta channel
to access the beta program
1. you must have bought the app through the google play store
2. join the Madsonic google group
3. join beta app page (2. link)
4. then i approve your request
5. google play store delivers beta apk
drrighteous
Been thanked: 5 times
Unread post by drrighteous »
For what its worth, the issue nh5 is reporting sounds like the same one I reported in the Bugs forum. Where pinned files (often transcoded FLAC) repeat download, I have also noticed that these same files cut off the last second of audio when streaming live.. This does not however happen in the web based player. I do have a song or two that this behavior is repeatable on if you would like me to send a file to you on PM.
These users thanked the author drrighteous for the post:
boco
Been thanked: 13 times
Unread post by boco »
Bug with Android 4.4 nexus 4 -
Clicking the Search icon on the bottom causes the app to crash. Bug report from app has been sent.
Also, where should we post bugs to? This Forum or the Google Groups list?
As always the new changes are looking really good.
Boco
These users thanked the author boco for the post:
Answers: 4
boco wrote:Bug with Android 4.4 nexus 4 -
Boco
Hi there, i have tested with Android 4.4, but i will recheck your report.
it would be better post beta problems in the google group list,
and problems with released versions in the forum.
rZn
Has thanked: 9 times
Unread post by rZn »
the login link does not work.. gives me an 404 at Google Play..
Regards.
Edit: Links works fine now (:
These users thanked the author rZn for the post:
psychicsaint
Unread post by psychicsaint »
Google play reports item not found.. I've enrolled as tester.. please help
Answers: 4
psychicsaint wrote:Google play reports item not found.. I've enrolled as tester.. please help
Please read this post: http://forum.madsonic.org/viewtopic.php ... 2518#p2498
xicor
Unread post by xicor »
it would be great if you could add the genre radio functionality that is on the full site.
kornkid5622
Has thanked: 4 times
Unread post by kornkid5622 »
Bug with version 5.6 on Moto G Android 4.4.4
when turning on the Song Shuffle (now called pandora mode) it says "Pandora Mode On" but doesn't load any songs at all, when i press play nothing happens, worked fine in Madsonic 5.5, other then that it seems to work very nicely but i hope this can be fixed soon, as i love this feature of Madsonic!
edit: sometimes when i try to press play after enabling pandora mode it says "Pandora-Buffer 0"
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech »
You may need to begin playing one song, then turn on Pandora mode.
kornkid5622
kornkid5622
gurutech wrote:You may need to begin playing one song, then turn on Pandora mode.
this workaround does get it working, thanks alot.
Answers: 4
It's not a bug, it's a feature ;)
Pandora on the Client works a little bit different as on the Webpage.
First, play some Music of your choice.
In the background, the song data will be collected and a buffer is created on the base of these. If the last but one song is reached,
new songs are loaded from the buffer. By moving the song to the last entry, you can pass through songs from the buffer.
I hope I haven't confused you more as before. ;)
kornkid5622
kornkid5622
this makes perfect sense, i suppose the confusing part was just that in version 5.5 it was the same icon for the plain old shuffle feature, is there any way we will get the old shuffle option back? i want to shuffle my entire library not just similar artists/songs as it did in version 5.5. either way thanks alot for the reply and clarifying that feature :)
Answers: 4
Yes it's there. Go to the welcome (first) page. In the Top bar the first icon is the old shuffle mode. :D
kornkid5622
kornkid5622
well, i suppose it was a bit of an oversight on my part then haha, thanks alot! the app is fantastic :)
These users thanked the author kornkid5622 for the post:
