Queue List Creation
rburns
Queue List Creation
Unread post by rburns »
In addition to change in the playlist workflow...
It would help if there was an option under More Actions... to "Play Selected Last" and "Play Selected Next"
These users thanked the author rburns for the post:
jaszladie
Has thanked: 11 times
Been thanked: 105 times
Re: Queue List Creation
Unread post by gurutech »
It's under the section "Selected Songs" already....
rburns
The only thing I see is add to playlist. I was looking for something that adds to QUEUE in order to compile a playlist.
If you choose Add to Playlist, it will either a) ask you for a name for a new playlist, or b) create a new playlist with the current date/time as the playlist name.
I haven't created playlists this way for a while. I create mine in iTunes (via "Genius"), then export them to *.m3u8 files, and move them to my playlist folder, where Madsonic will import them automatically.
good idea, added to the 5.1 brunch.
z-vap
Unread post by z-vap »
yeah I was just wondering about this. I had an album with 30 songs in it, and just wanted several random songs on that added to the play queue below. I couldn't figure it out. I was like "where is the "Add Selected" choice"?
Glad this being added :)
