In addition to change in the playlist workflow...
It would help if there was an option under More Actions... to "Play Selected Last" and "Play Selected Next"
Queue List Creation
- Been thanked: 105 times
Re: Queue List Creation
If you choose Add to Playlist, it will either a) ask you for a name for a new playlist, or b) create a new playlist with the current date/time as the playlist name.
I haven't created playlists this way for a while. I create mine in iTunes (via "Genius"), then export them to *.m3u8 files, and move them to my playlist folder, where Madsonic will import them automatically.
yeah I was just wondering about this. I had an album with 30 songs in it, and just wanted several random songs on that added to the play queue below. I couldn't figure it out. I was like "where is the "Add Selected" choice"?
Glad this being added
