Hi Madsonic Community!
Well i'm back again, after some weeks long busy at work.
I'll look through the support forum and hopefully can clarify many things.
but I have also good news which have occurred more in the background.
new 5.0 Build 3860
merged many subsonic 4.9 bug-fixes and improvements
new 5.1 Development Branch started
the new build is already being processed.
5.1 development goals
- merge Last.FM API to main project, better integration with cache location (NAS)
- extend Last.FM API Calls and DB (getTopTrack, get/setLovedTracks, getCharts, getAlbumImage, metaData, ...)
- expand Pandora API to Clients and user profiles
- extend REST API to Clients - more Metadata exchange
- increase transcoding compatibility (support avconv, mencoder, ogg, subtitle, ...)
- extend security groups (max audio/video transcoding settings)
- extend video capabilities (metadata, visualization, transcoding)
- Upgrade JWPlayer to http://mediaelementjs.com
- new user-controllable "mediatag" system
- new user-controllable Playbutton system
- streamline interface
- many more
Madsonic Client Google Store
all issues are cleared and the Madsonic app is back online on the Google Play Store
Madsonic Client improvements
many improvements will follow the first beta of the 5.1 server build
new Madsonic "Node" design phase started
more details about this new project will be published later.
Update UnRAID x86 Plugin
Update to newest Bugfix release 3860
new unRAID x64 Plugin
Create new Plugin for the unRAID 6.0 beta3 (x64) version
new Synology Plugin
Create new Plugin for the Synology NAS Series
maybe QNAP Plugin
Best Regards,
