Android Player Compatability...
Re: Android Player Compatability...
Do you get any error, infos or other messages ?
what device, type or model do you use?
No error messages, this is a Sony Co-Star which is the hardware for the Google TV system which is Android Based. I have the Play Store but a search for Madsonic will return zero results. Madsonic does not show up because Google for some reason thinks it's not compatible with the Google TV environment.
I could side load it, but I'm still researching how to root the device, which seems like that will be very difficult at this point in time.
I am able to get my videos to play on the TV (with Google TV) by using Chrome and openening the Madsonic Webpage but the streaming is spotty at best.
The Android Madsonic interface has so far provided the best results in an Android envirornment.
I'll get model number and other relevant information this evening when I'm finished working.
well i found the problem with the google store filter
https://developers.google.com/tv/androi ... atureCheck
i will fix this with next release
Thank you.
Next thing with this unrooted Google TV is I don't think I can get Java installed, still investigating.
I know it has Java Script operating.
****Edit to Remove Comments, MXPlayer just released a Google TV compatible version****
