I have a small problem,
In madsonic app, I have to reset it every time I want to switch kbps.
And if i use the app from a mini neo x5 mini, the film
Freezes each 5-10 minutes (using mx player) I have seen this problem from 3660 and up.
Anyone else have this problem?
(I'm using ssl if it matters)
/ Sincerely Chali
freezes
Re: freezes
what are the results from other players: BS Player, VLC, Flash, HTML5 ?
chali
- Has thanked: 18 times
- Been thanked: 35 times
Re: freezes
vlc and Bs do not work at all,
flash starts and you can change kbps.
with html5 I just get error message, (I've only tested one time ,i can try again during the day.
Regards / Chali
Regards / Chali
Madevil wrote:hi there,
chali
Re: freezes
hello again
Now I begin to wonder what is going on?
first loads the movie over and over again (downloading it several times in a loop (many gigs)) then starts streaming the film normal, with a few mb / s and then just stop working after 20-30 minutes?
This is on all android computers,
(it works ok on the pads I tested on (not to changs kbps but it dont freez)
following android is the problem: Minix neo x5 mini, cs918, mk808.
it's like not transcoding works, it does not matter if I put the max kbps to 200 or 5000, the picture is the same.
or is it that you can not use transcoding while streaming a movie from the server with the app and mx player?
(that would explain a lot =))
for example, I know several cpu with these android PCs have problems
with movies that are not divisible in 16 modulus.
some films work better, but the only difference in them is that one version is ripped with 8 b-fram and the other 4-b frame (ripped several versions the same to run image tests)
/ Sincerely Chali
/ Sincerely Chali
