Version 5.0.3560.beta4 Dates
BKKKPewsey
Has thanked: 4 times
Unread post by BKKKPewsey »
Just downloaded the latest beta an noticed something odd.
I also added a couple of new albums at the same time and Madsonic is stripping the date info from the path from those NEW albums.
The Themata album I noticed had my old structure of <year> <album> (no hyphen) and did display correctly but when I changed it to add the hyphen ( hence MS thought it was new) the date then disappeared :roll:
The folder path contains the date in the format <year> - <album title>
Of course this is now messing up the sort as they are no longer in ascending date order
But the albums scanned in previous still display (and sort) ok
eg
:mrgreen:
These users thanked the author BKKKPewsey for the post:
GJ51
Has thanked: 42 times
Been thanked: 83 times
Re: Version 5.0.3560.beta4 Dates
Unread post by GJ51 »
So what's a Themata? :mrgreen:
there is a to enable/disable setting to hide/show the extracted year
BKKKPewsey
Madevil wrote:here is a to enable/disable setting to hide/show the extracted year
Yes I am aware - if I tick that option I get this :-
Note still sorting on alphabetical sort
The albums scanned in with the previous version still show correctly in date order
And to answer GJ - I have no idea :lol:
:mrgreen:
Re: AW: Version 5.0.3560.beta4 Dates
In the next build, a make a option to disable the year parsing.
BKKKPewsey
GJ51
I just hope that's not an imparsible thing to do ... :lol:
Still the best ... and only active version of Subsonic being worked on!!
Thanks Madevil - another support donation coming your way when 5.0 hits RTM.
BKKKPewsey
GJ51 wrote:Still the best ... and only active version of Subsonic being worked on!!
Indeed!!!
:mrgreen:
djiai
5.0.3560.beta4
Unread post by djiai »
hello,
I tested last night the new version. I think I found a bug.
1- Random way the lists of directories is accessed reactualize aléatoiremen every 10 seconds to 45 seconds.
Improper adjustment on my part or bug?
2- Is it normal to have 40 subsonic process during intensive use?
Sorry for my english! :?
