Massive Logging Improvements
Posted: 08 May 2019, 15:43
by KaeTuuN
Madsonic Loglevel: VERBOSE
Configured an SMTP Server -> NO Log entries
Added a New User -> 1 Log entry (Created User xyz)
That's not what I expect on Loglevel "VERBOSE". Could you please implement lots more Logentries?
Logentries I expected on this two actions:
SMTP Server:
ERROR:
  • Server unreachable
  • Wrong Password/Username
WARN:
  • Unsecure Connection if encryption "none" is selected
INFO:
  • SMTP successful configured
    DEBUG:
    • SMTP Server and Port
    • Used encryption
    • Mail sender
    • SMTP Username
    VERBOSE:
    • Start/Finish cheking connection
    Add a new User:
    ERROR:
    • User already exists
    • Can't create User because of ???
    WARN:
    • Weak Passwort used
    • User is Administrator
    INFO:
    • User Created xyz
    • Mail Adress
    • User Level:
    DEBUG:
    • All other Settings
    If the Loglevel is on "VERBOSE" the Logfile should be spammed with Massages...
    At the Moment I don't even now, if my SMTP configuration is correct or not...
    Greetings Kae
