Don't get Server 7.0 to run on macOS
janpeeters
Unread post by janpeeters »
I noticed that there is currently no macOS build of Server 7 so I installed the Stand-alone zip version (all platforms). It doesn't startup though. Has anyone succeeded in getting it to run on macOS. Suggestions would be welcome! Thanks, Jan
VERSION: MADSONIC 7.0 | BUILD: 10390
SERVLET: JETTY | TOMCAT | JBOSS | OTHER
SERVER: CPU: 2,3 GHz Intel Core i5 | ARCH: X64 | MEMORY: 8GB | HDD: 250Gb SSD
OS: macOS
SYSTEM: 10.13.6
INSTALLER: STANDALONE
JAVA: ORACLE JDK 13 and Java 8 (latest)
BROWSER: SAFARI
DESCRIPTION: Doesn't startup
REPRODUCIBLE: Yes
These users thanked the author janpeeters for the post:
Re: Don't get Server 7.0 to run on macOS
We try to make Madsonic 7.x compatible on all existing Java platforms. JAVA 1.8, 11, 12 and 13 are currently supported.
For MacOS we have now submitted an installer, which also works with your MacOS 10.13.x version.
Installation :arrow: https://www.madsonic.org/pages/installation.jsp#mac
Download :arrow: https://www.madsonic.org/pages/download.jsp
martin-juul
Unread post by martin-juul »
Download link for v7 is not available.
jsbi
Unread post by jsbi »
Tried to install on MacOS (running Catalina 10.15.7) no luck. Below are steps I followed.
1. Installed JRE 7and rebooted the Mac.
2. Downloaded the Mac pkg for ver 7 and installed - installation went fine and placed an icon in Applications.
3. Clicking the icon does nothing.
4. No page displayed in http://localhost:4040/
Troubleshooting:
1. Tried running /Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub
Below is output:
J-Mac-mini:~ js$ /Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub ; exit;
/Applications/Madsonic.app/Contents/MacOS/universalJavaApplicationStub: line 32: /Library/Internet: No such file or directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
There are 3 folders in the location /Library/Application Support/Madsonic
They are config,logo and transcode
Let me know if any additional steps I need to do.
Tried restarting the machine as well - no luck. So also installing again.
Please guide.
SERVLET: Not sure what this means
OS: macOS
SYSTEM: 10.15.7
INSTALLER: Mac OS
JAVA: ORACLE Java 8 Update 271(latest)
BROWSER: Chrome
REPRODUCIBLE: Yes
