[SOLVED] Can't log in to download v7
Posted: 29 Apr 2019, 15:25
by garyo
I'm getting "Invalid Account" after entering my email addr, trying to log in to download v7. Is it just me?
[SOLVED] Re: Can't log in to download v7
Posted: 29 Apr 2019, 15:33
by garyo
OK, weird -- after a bunch of failures, I went back & clicked the download link again and now it let me through. OK, don't know what that was, but I've got v7 now -- off to install it!
Re: [SOLVED] Can't log in to download v7
Posted: 05 May 2019, 15:10
by Sm0k3d0uT
Where do you download 7 from? All i see is 6.2
Posted: 07 May 2019, 07:33
You can activate the view on the download page with the link below.
Posted: 18 Jun 2019, 01:06
by thechez
Yes, this same thing is happening for me. When I attempt to log in to get to the v7 page it says I'm an invalid user.
Also, the 6.3 server keeps dropping my license. Then I can't access my music until I go home and can reset things. Is anyone else having that issue?
Posted: 15 Aug 2019, 19:22
by Ender
yes same problem her
