[SOLVED] Error 403 after upgrade using Debian package
Posted: 29 Apr 2019, 14:51
by troycarpenter
Got the following error after upgrading from 6.3.9840 to 7.0.10380 using the new Debian installer and trying to open the web interface:
HTTP ERROR 403
Forbidden
Powered by Jetty:// 9.4.z-SNAPSHOT
Remote clients (Android, iOS) are not working either.
Re: Error 403 after upgrade using Debian package
Posted: 29 Apr 2019, 15:31
by troycarpenter
Adding startup logs:
Apr 29, 2019 10:22:06 AM org.springframework.context.support.ClassPathXmlApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1e80bfe8: startup date [Mon Apr 29 10:22:06 EDT 2019]; root of context hierarchy
Apr 29, 2019 10:22:07 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
Apr 29, 2019 10:22:07 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@7e0ea639: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
No newer update found.
2019-04-29 10:22:08.144:INFO::main: Logging initialized @2397ms to org.eclipse.jetty.util.log.StdErrLog
Extracting webapp to /var/madsonic/jetty/10380
Using GZIP-compression.
2019-04-29 10:22:08.767:INFO:oejs.Server:main: jetty-9.4.z-SNAPSHOT; built: 2019-04-18T19:45:35.259Z; git: aa1c656c315c011c01e7b21aabb04066635b9f67; jvm 1.8.0_201-b09
2019-04-29 10:22:11.868:WARN:oeja.AnnotationParser:main: Unknown ASM version, assuming ASM7
2019-04-29 10:22:13.166:INFO:oeja.AnnotationConfiguration:main: Scanning elapsed time=1296ms
2019-04-29 10:22:13.215:INFO:oejshC.ROOT:main: No Spring WebApplicationInitializer types detected on classpath
2019-04-29 10:22:13.455:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0
2019-04-29 10:22:13.455:INFO:oejs.session:main: No SessionScavenger set, using defaults
2019-04-29 10:22:13.460:INFO:oejs.session:main: node0 Scavenging every 660000ms
2019-04-29 10:22:13.475:INFO:oejshC.ROOT:main: No Spring WebApplicationInitializer types detected on classpath
Initializing MadsonicContextListener
2019-04-29 10:22:13.490:INFO:oejshC.ROOT:main: Initializing Spring root WebApplicationContext
[2019-04-29 10:22:14] [INFO ] [main] Version - HV000001: Hibernate Validator 6.0.16.Final
[2019-04-29 10:22:17] [INFO ] [main] EhcacheManager - Cache 'mediaFileMemoryCache' created in EhcacheManager.
[2019-04-29 10:22:17] [INFO ] [main] EhcacheManager - Cache 'userCache' created in EhcacheManager.
[2019-04-29 10:22:18] [INFO ] [main] FluentPropertyBeanIntrospector - Error when creating PropertyDescriptor for public final void org.apache.commons.configuration2.AbstractConfiguration.setProperty(java.lang.String,java.lang.Object)
! Ignoring this property.
[2019-04-29 10:22:20] [INFO ] [main] ReflectionServiceFactoryBean - Creating Service {http://service.madsonic.org/}SonosServiceService from class com.sonos.services._1_1.SonosSoap
[2019-04-29 10:22:21] [INFO ] [main] ServerImpl - Setting the server's publish address to be /Sonos
2019-04-29 10:22:22.125:INFO:oejshC.ROOT:main: Initializing Spring FrameworkServlet 'madsonic'
2019-04-29 10:22:23.691:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@1b5af65b{Madsonic Music Streamer,/,file:///var/madsonic/jetty/10380/webapp/,AVAILABLE}{madsonic.war}
2019-04-29 10:22:23.710:INFO:oejs.AbstractConnector:main: Started ServerConnector@78c03f1f{HTTP/1.1,[http/1.1]}{0.0.0.0:4040}
2019-04-29 10:22:23.715:INFO:oejus.SslContextFactory:main: x509=X509@1dd76982(madsonic,h=[madsonic.org],w=[]) for SslContextFactory@7e76a66f[provider=null,keyStore=jar:file:/usr/share/madsonic/madsonic-booter.jar!/madsonic.keystore,t
rustStore=null]
2019-04-29 10:22:23.724:INFO:oejs.AbstractConnector:main: Started ServerConnector@43814d18{SSL,[ssl, http/1.1]}{0.0.0.0:8074}
2019-04-29 10:22:23.724:INFO:oejs.Server:main: Started @17977ms
                and: https://localhost:8074/
2019-04-29 10:22:26.131:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:22:35.474:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:22:45.523:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:22:55.553:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:05.585:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:15.622:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:25.672:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:35.769:WARN:oejs.SecurityHandler:qtp1204167249-13: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:45.814:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:50.152:WARN:oejs.SecurityHandler:qtp1204167249-43: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:50.371:WARN:oejs.SecurityHandler:qtp1204167249-13: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:23:55.845:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:05.883:WARN:oejs.SecurityHandler:qtp1204167249-13: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:15.922:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:25.941:WARN:oejs.SecurityHandler:qtp1204167249-13: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:36.063:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:46.222:WARN:oejs.SecurityHandler:qtp1204167249-13: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:24:56.259:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:06.272:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:16.304:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:26.334:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:36.403:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:46.435:WARN:oejs.SecurityHandler:qtp1204167249-14: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:25:56.485:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:06.535:WARN:oejs.SecurityHandler:qtp1204167249-44: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:16.593:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:26.623:WARN:oejs.SecurityHandler:qtp1204167249-44: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:36.674:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:46.698:WARN:oejs.SecurityHandler:qtp1204167249-44: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:26:56.754:WARN:oejs.SecurityHandler:qtp1204167249-42: No authenticator for: {RoleInfo,C[],None}
2019-04-29 10:27:06.824:WARN:oejs.SecurityHandler:qtp1204167249-15: No authenticator for: {RoleInfo,C[],None}
From what I've read online, it probably has something to do with the authenticator error at the end of the log.
Posted: 29 Apr 2019, 16:36
by troycarpenter
Still working this, but it appears there something in my /etc/default/madsonic file. When I commented out all startup args in that file, the http interface came up. I'll update this when I've figured out what's doing it.
UPDATE: The problem seems to be happening when specifying an https port for startup. There must be something not right in the new WAR file for SSL authentication. Guess I've got to resort to a wrapper to regain SSL access until it's fixed.
Workaround
Posted: 29 Apr 2019, 18:40
by troycarpenter
One final note from me. To fix this quickly for my users, I've added a proxy redirect to send https traffic to the http port in the background (I've done this for many of my services that don't support https but need https encryption). This is probably the better solution since I no longer have to worry about packaging my certificates in a way that Madsonic understands.
Posted: 30 Apr 2019, 09:46
by KaeTuuN
This is probably the better solution...
Well... I'm not sure. If you use modern HTTPS security features, which you should do, you can't forward non HTTPS Traffic through HTTPS. You should think of that!
Back to your Problem: Have you checked the Key File Permissions? If Madsonic 6.xxx runs with user Madsonic_Server and Madsonic 7.xxx runs with another user. The new user might have no permissions to read the file.
Greetings Kae
Posted: 30 Apr 2019, 16:31
by troycarpenter
I've reproduced it on a clean install if all you do is enable https in the startup arguments, so I doubt that's the issue. My guess is there's something missing in the https handling or configuration in the new version using the new security framework.
Posted: 07 May 2019, 17:20
by a6595085
I have the same problem of this discussion.
I'm running madsonic 7.0 server on Windows 10.
It also comes out 403 forbidden on https site,
and server log showing WARN:oejs.SecurityHandler:qtp2083089641-111: No authenticator for: {RoleInfo,C[],None}
Hope it can be fix in next update,Thx.
Posted: 07 May 2019, 17:23
by a6595085
I'm running madsonic 7.0 server upgraded from 6.3.9840 on Windows 10.
Posted: 07 May 2019, 20:57
by KaeTuuN
 VERSION:      MADSONIC 7.0 | BUILD: 10380
 SERVLET:      JETTY
 SERVER:       CPU: Core i3-6100 | ARCH: X64 | MEMORY: 16GB
 OS:           Ubuntu 18.04 LTS Server
 SYSTEM:       SERVER
 INSTALLER:    DEB
 JAVA:         OPEN JDK 1.11.0.2
 BROWSER:      ALL
 CLIENT:       ALL
 DESCRIPTION:  Not reachable if HTTPS is enabled
 REPRODUCIBLE: YES
I also tried to use HTTPS and can confirm the Error.
This entry is created everytime someone tries to open the madsonic webpage or tries to connect via an android app.
I set the Loglevel to "DEBUG" but that seems to work only for "madsonic.log" and not for "madsonic_sh.log", so this is the only Information I have.
@Madsonic Team:
Is there anything we can do? Test some settings, post some logfiles or anything else?
I'm willing to help, so let me know, what I can do! I'm really interested in a (really) working SSL Version.
Greetings Kae
EDIT:
Did some more Research.
  • Using HTTP and HTTPS makes both unreachale -> same error
  • It makes no difference, if you edit the args at "/etc/default/madsonic" or directly at "/usr/share/madsonic/madsonic.sh"
  • Setting HTTPS Port to 0 and using only "Dmadsonic.ssl.keystore" and "Dmadsonic.ssl.password" Args let Madsonic work normal with HTTP
  • If the HTTPS Port is not 0 the Error occurs (Tested 4443, 8080, 8443, 12345, 50000)
  • In all Cases Madsonic says: "Madsonic running on: http://localhost:4040/" and "Madsonic running on: https://localhost:<HTTPS-PORT>/"
Posted: 08 May 2019, 15:33
by ecac
I am having the same exact issue and I am no where as technical as you guys are - just a basic premium home user! Anyone know how I can get this to work until Madsonic responds?
Posted: 08 May 2019, 16:57
by KaeTuuN
@ecac:
At the Moment there is no Solution, just a Workaround, which doesn't work for everyone.
So the best Way would be to open a new Thread, using this Header: viewtopic.php?f=2&t=1520
Greetings Kae
Posted: 10 May 2019, 18:03
The problem with the security authenticator is fixed with the new build 7.0.10390.
Posted: 11 May 2019, 20:40
by KaeTuuN
Works great, thanks!
Greetings Kae
