Playqueue behavior when selecting from the Index
Posted: 27 Jul 2016, 23:46
Essentially I am looking for the option to change the behavior of adding songs to the play queue when browsing music. Here is how I envision it working.
Hopefully this could be a setting that can be changed per user but if not then at least a setting that each admin can set for their server.
- 1. Select Artist from Index/Artist list
2. Select Album from available Albums
3. If the user selects a song from the tracklist, the play queue will remove all current entries and be populated with the full album listing. Playback will start at whichever song was selected.
4. I used the words Artist and Album but these are just directories so I guess if someone has their music organized differently, the main idea is that if you are viewing a directory and select a file that is in it, it will wipe the play queue and repopulate it with available files in that directory with play back starting at the selected file
