[SOLVED] Problem with DLNA UPnP in 6.3.9700
Posted: 17 Oct 2017, 18:21
by chrissi55
 VERSION:      Madsonic 6.3.9700
 SERVLET:      Integrated with madsonic, (Jetty).
 SERVER:       CPU: Xeon E3-1230 v5 | ARCH: x64 | MEMORY: 32GB | HDD: 10 TB
 OS:           ubuntu Server 17.04.1
 SYSTEM:       Server
 INSTALLER:    Deb
 JAVA:         Oracle JRE 1.8 build 144
 BROWSER:      SRware Iron, Chromium 61.x, FF 56.x
 CLIENT:       KODI 17, DUNE HD Max
 DESCRIPTION:  Not playing Audio or Video Files
 REPRODUCIBLE: Yes
I activated the build in DLNA / UPnP Server in 6.3.9700
My DLNA Appears in DUNE HD Player and Kodi with it's "friendly Name" -> so far so good.
But when klicking to a mp3 or videofile (mp4 or avi) Player says "Serververbindung nicht möglich" Error (16) , or , "Fehler, Format wird nicht unterstützt"??
With 6.2.xxx Version of madsonic Server this wasn't a Problem.
The logfiles are very empty for that.
Strange, strange.
The files where playing via NFS Share very well but not via DLNA.
Audio files on a third Client (a Pure HD Audio / Radio) are also not played any longer.
Same tested with earlier stable Version 6.2.xxx was also here not a prob.
Any things to do - to figure out what's wrong?
Regards :-)
Re: Problem with DLNA UPnP in 6.3.9700
Posted: 18 Oct 2017, 16:49
by chrissi55
I switched my loglevel to DEBUG and get the following when connecting to an UPnP Source ..
[2017-10-18 17:44:24,531] DEBUG FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: dc:title,dc:date,res,res@size,upnp:class,upnp:originalTrackNumber, firstResult: 0, maxResults: 20
[2017-10-18 17:44:27,269] DEBUG FolderBasedContentDirectory - UPnP request - objectId: folder-0, browseFlag: BrowseDirectChildren, filter: dc:title,dc:date,res,res@size,upnp:class,upnp:originalTrackNumber, firstResult: 0, maxResults: 20
[2017-10-18 17:44:28,507] DEBUG FolderBasedContentDirectory - UPnP request - objectId: folder-122528, browseFlag: BrowseDirectChildren, filter: dc:title,dc:date,res,res@size,upnp:class,upnp:originalTrackNumber, firstResult: 0, maxResults: 20
Any helping idea?
Posted: 20 Oct 2017, 15:38
by chrissi55
The following worked for me
Changing the Tags for "Guest" for each group to disabled
Re-Scanned all files.
Then changed again the Tags for "Guest" for each group to enabled.
Made a Full-Rescan without cleaning
After that i could reach and play files on my DUNE HD, so in my foobar2000 player with UPnP PlugIn installed.
KODI didn't it's job - don't know why, but could be a problem with KODI and not with madsonic DLNA.
