Podcast Receiver Can't handle episodes with same name
troycarpenter
Has thanked: 22 times
Been thanked: 49 times
Unread post by troycarpenter » 27 Jan 2017, 17:40
I have an XML feed from a provider where the final filename for all the podcast episodes are the same. The differentiator is in the download URL. For instance:
http://example.com/wednesday/episode.mp3
http://example.com/thursday/episode.mp3
http://example.com/friday/episode.mp3
You can see that the URL path is different even though the filename is the same.
The problem is that Madsonic wants to dump these files into the same podcast directory on the server, which results in a collision. Once the first episode is downloaded, the remaining episode downloads are aborted claiming the file has already been downloaded. However, in the podcast web interface in Madsonic (and in the database), it shows all queued episodes have been downloaded.
It would seem like in this situation, the podcast downloader could detect the filename collision, generate a new filename using some type of algorithm to save the file, and save that into the database.
For the filename algorithm, a possibility would be to concatenate the podcast date + server time (in case the dates are also the same) to the filename provided in the xml feed.
Has thanked: 1146 times
Been thanked: 447 times
Re: Podcast Receiver Can't handle episodes with same name
Unread post by Madsonic » 31 Jan 2017, 08:41
troycarpenter
troycarpenter
Unread post by troycarpenter » 08 May 2017, 20:50
Using MADSONIC 6.2.9260.
This is still happening. Podcast example:
http://feeds.podtrac.com/EJbKUnHP5ywQ
In this case, all the episodes are called "download.mp3", but the path is different for each one. It appears that whatever is downloading the episodes is appending an extra number to the episode filename, but not including it in the database.
I'm looking to see if there is another feed that doesn't include the duplicates, but I doubt there is.
Unread post by Madsonic » 18 May 2017, 07:31
This is fixed with the next 6.3 release. :thumbsup:
