Raspbian new install - Java issues
Posted: 25 Jan 2019, 22:19
OK - I have followed various instructions, including this "installing-oracle-java-jdk-8-on-raspberry-pi " on "raspinews<dot>com" - sorry can't post links as noob on forum
When I use
java -version
I get
Cheers
Eserim
When I use
java -version
I get
Yet when I try to install Madsonic server 6, I getjava version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) Client VM (build 25.201-b09, mixed mode)
Have I missed something crucial somewhere.dpkg: dependency problems prevent configuration of madsonic:
madsonic depends on default-jre | default-jre-headless | openjdk-8-jre-headless | openjdk-7-jre-headless | openjdk-7-jre | openjdk-8-jre; however:
Package default-jre is not installed.
Package default-jre-headless is not installed.
Package openjdk-8-jre-headless is not installed.
Package openjdk-7-jre-headless is not installed.
Package openjdk-7-jre is not installed.
Package openjdk-8-jre is not installed.
dpkg: error processing package madsonic (--install):
dependency problems - leaving unconfigured
Processing triggers for systemd (232-25+deb9u6) ...
Errors were encountered while processing:
Cheers
Eserim
