how can i save the generated cover art ?
Posted: 04 May 2018, 08:19
by a7medo778
hi guys, i have a BIG library of local tracks
i love the fact that madsonic generates temp cover arts, but is there a way to save it at the media folder or even better write it to the ID3 field of the mp3's ?
with regards
ahmad
Re: how can i save the generated cover art ?
Posted: 06 May 2018, 03:15
by Matt Zornig
a7medo778 wrote:is there a way to save it at the media folder or even better write it to the ID3 field of the mp3's ?
Check the Screenshot
here (for Artists). I don't exactly remember where to find the Button to save Coverarts, but AFA
IR there was an option... maybe in the same place?
Also, you can try to click this tiny and non-significant icon :-)
- shows covers from last.fm
Posted: 06 May 2018, 06:58
by a7medo778
Matt Zornig wrote:a7medo778 wrote:is there a way to save it at the media folder or even better write it to the ID3 field of the mp3's ?
Thanks for the answer mat, but i am not looking to search for the actual art (it doesnt exist since its really local/indie), i want to save those temp generated ones (like this) in the id3 field of the file it self
Sent from my iPhone using Tapatalk
Posted: 06 May 2018, 11:36
by Matt Zornig
a7medo778 wrote:i want to save those temp generated ones (like this) in the id3 field of the file it self
Ok, I see, that could be very timeconsuming because this Image has an overlay, so you can't just "Save as..." by hand easily... hmm... really a pitty, because I like those generated covers too :-D
I use an
old FireFox Addon "Save Images" to save all Images from a WebPage to disk and it worked, but that seems to be very cumbersome for just saving a lot of covers.
- Bild_034.png (7.89 KiB) Viewed 7157 times
Posted: 06 May 2018, 11:49
by a7medo778
Yeah exactly my thoughts, thats why i was asking if we can write them to the id3 field same as we do with genre and artist info
