Probably a Java problem !!
Posted: 07 Dec 2016, 13:26
by Aktarus
Hello
My Madsonic was already installed in my DS412+ and was running fine..
I update to DSM6.1 beta and Madsonic 6.2 latest version last week, and now I have some trouble ...
Madsonic is running but no more library scan update...and left frame error ...and nothing already scan wants to play !!!!!
My log file looks like this :
[01/12/16 07:36] ERROR SearchService Failed to create search index.
[01/12/16 07:36] ERROR MediaScannerService ERROR PreparedStatementCallback; SQL [update artist set song_count=0, play_count=0]; java.lang.OutOfMemoryError: Java heap space; nested exception is java.sql.SQLException: java.lang.OutOfMemoryError: Java heap space
[01/12/16 07:36] ERROR MediaScannerService Failed to scan media library.
The Left Frame error looks like this :
Error
Exception org.springframework.dao.DuplicateKeyException
Message PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; integrity constraint violation: unique constraint or index violation; SYS_PK_10479 table: MEDIA_FILE; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: unique constraint or index violation; SYS_PK_10479 table: MEDIA_FILE
Java version Oracle Corporation 1.8.0_112
Operating system Linux 3.10.102
Server jetty/8.y.z-SNAPSHOT
Memory Used 92 of 375 MB
Stack trace org.springframework.dao.DuplicateKeyException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, override, format, data, title, album, album_name, artist, album_artist, disc_number, track_number, year, genre, mood, bpm, composer, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, first_scanned, children_last_updated, present, version, rank) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; integrity constraint violation: unique constraint or index violation; SYS_PK_10479 table: MEDIA_FILE; nested exception is java.sql.SQLIntegrityConstraintViolationException: integrity constraint violation: unique constraint or index violation; SYS_PK_10479 table: MEDIA_FILE
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:245)
at org.madsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:255)
at org.madsonic.service.MediaFileService.getMediaFile(MediaFileService.java:148)
at org.madsonic.service.MusicIndexService.createSortableArtistsforGenre(MusicIndexService.java:276)
at org.madsonic.service.MusicIndexService.getIndexedArtistsforGenre(MusicIndexService.java:146)
at org.madsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:167)
at org.madsonic.controller.LeftPanelController.handleRequestInternal(LeftPanelController.java:248)
It semms to be a Java memory problem, but I don't know what to do ... I'm running latest Java 8SDK for synology ..
I also have Subsonic installed in the same NAS and everything goes fine with it ....
Please, help me to solve my madsonic problem...
Merci .. and sorry for my poor english :)
Re: Probably a Java problem !!
Posted: 08 Dec 2016, 21:06
It seems your installation is in a critical situation with memory and database errors.
Try to uninstall and start from scratch with the new installer 6.2.9040. (this version use more memory if available on your DSM hardware).
Posted: 08 Dec 2016, 21:52
by Aktarus
I tried it but I get an error diring Install process ...
I unistall completely Madsonic ... remove Madsonic Public folder ... and the madsonic folder at root ..
When I want to reinstall with the latest 6.2 version, I get an error ... I recreate the Madsonic folder in the public folder with 777 permission .. without any success ...
Please help me :?
Posted: 08 Dec 2016, 22:52
the last Madsonic installer works on official supported version
can you tell me more about the system specification and the error message ?
Posted: 08 Dec 2016, 23:27
by Aktarus
I know,... it worked for me until last week in this DSM version, but I update do DSM 6.1 Beta AND Madsonic 6.2 in the same day (monday)..
Since this time, I had trouble and java error and nothing was working...
So, I completely uninstall my Madsonic, and since this time, no more able to re-install it :(
Sorry for my poor english ... mais MERCI BEAUCOUP de m'aider :)
Posted: 13 Jul 2017, 01:39
by SysopChris
I think I'm getting the same type of error. I'll post it here.
Did you find a fix?
I'll post a screenshot, this does not allow copy/paste due to spam restrictions.
