FAQ] Madsonic Install Starter Guide
Answers: 4
Has thanked: 1171 times
Been thanked: 457 times
INFO
WARNING
1.st make a backup of your whole Subsonic folder, to go back if something goes wrong !!!
INSTALL/UPGRADE INFO
You should only need the installation packages, no other installations or workarounds are needed!
Since Beta the Upgrade works much better, the Installer also make a Backup from the DB folder,
but i still recommend a installation from Scratch!
Since Build 3120 Upgrade from Subsonic 4.6, 4.7 supported
5 quick steps to upgrade
  • stop Madsonic script/service
  • replace madsonic.war & madsonic-booter.jar
  • clean browser caches
  • restart madsonic
  • rescan files
WINDOWS
  • [1] just use the installer to install or upgrade your installation.
TOMCAT
  • [1] remove old war
    [2] delete work folder
    [3] redeploy new war file
LINUX
[FAQ] Update madsonic with a war package on debian linux
[Script] Upgrade madsonic on debian linux
Short Instruction for new/existing Ubuntu/Fedora installation:
  • [1] Fresh Ubuntu/Fedora Install
    [2] Install Java 1.7 JRE/JDK (sudo apt-get install openjdk-7-jdk)
    [3] Config current JRE/JDK to 1.7 with:
    [#] sudo update-alternatives --config javac
    [4] check config with
    [#] javac -version
    [1] Start Firefox -> Check Java Version -> browse -> http://javatester.org
    [6] Install Adobe Flash Player
    [7] Uninstall all current subsonic/madsonic version
    [8] If exist delete folder /var/subsonic or /var/madsonic
    [9] Create /var/media folder
    [10] Put Content into /var/media
    [11] Install the madsonic Server deb/rpm)
    [12] Check if Service is running
    [#] sudo service madsonic start
    [13] Start Firefox -> browse -> http://localhost:4040
    14. Config subsonic via Webpage
    15. Done! :D
linux Defaults
/var/madsonic --> user db, settings, logs
/usr/share/madsonic --> madsonic.war, madsonic-booter.jar, madsonic.sh
/etc/int.d --> madsonic daemon (script)
/etc/default --> madsonic daemon (settings)
Complete Cleanup from Scratch
  • stop madsonic server
  • uninstall madsonic
  • delete folder c:\madsonic or /var/madsonic
  • cleanup all Browser Caches
  • cleanup all temp files
Conversion guide from older windows build version < 3630
  • make backup of c:\subsonic folder
  • uninstall older madonic version
  • install new madsonic version
  • stop service
  • copy back the db folder back from your madsonic backup
  • copy back the subsonic.properties file and rename it to madsonic.properties
  • start service
  • check user, settings, mediafolders
  • make full scan
  • finished, now all your old config should be back!
Conversion guide from older linux build version < 3630
  • stop madsonic daemon
  • make backup of /var/subsonic folder
  • stop daemon
  • copy back the db folder back from your madsonic backup into /var/madsonic
  • copy back the subsonic.properties file into /var/madsonic/ and rename it to madsonic.properties
  • start daemon
  • make full scan
Data Migration guide from older version
  • 01. stop madsonic service
    02. backup! (zip or copy) your old subsonic/madsonic installation (in your case c:\subsonic) !!!
    03. move your backup to a save place
    04. uninstall all Madsonic installation
    05. delete all old traces -> (c:\subsonic, c:\madsonic, c:\supersonic and \var\subsonic, \var\madsonic, \var\supersonic)
    06. make a new madsonic installation
    07. after installation the service will automatically start (new DB will created)
    08. stop madsonic service
    09. delete DB folder again (in your case c:\madsonic\db or \var\madsonic\db)
    10. delete settings file (madsonic.properties)
    11. copy your backup (DB folder and subsonic.properties only!) into your madsonic installation folder (c:\madsonic\)
    12. rename subsonic.properties to madsonic.properties
    13. restart Madsonic service
    14. Madsonic detect automatically the db version and will upgrade to newest Madsonic db structure layout
    15. possibly it can't hurt to go through all your settings and even press the save button on every settings page
    16. make a Full Scan Mediascan
    17. hopefully all is done
Andrusa3tcetera
Rating: 15.38%
pcburner
Re: Starter Guide
Unread post by pcburner »
First I just want to say thanks for you hard work and dedication. When I do the update for Madsonic from 3760 to 3780, I'll use the script that's provided in the forum, it'll run and finish with no errors also bear in mind that I'm do not have Subsonic installed. However, when I do an "about" it says I'm still using the previous version. Now I've tried it several different ways: First, removed and uninstalled subsonic & Madsonic, then reinstalled subsonic then installed Madsonic thinking Madsonic would overwrite the subsonic files. That didn't work. Finally, I removed Subsonic altogether and installed Madsonic but I'm still not able to accomplish the upgrade. I'm running Ubuntu 12.10 Server via terminal.
Answers: 4
Re: FAQ] Madsonic Install Starter Guide
Update migration Info
oxias
Unread post by oxias »
I've installed on my ubuntu (x64) server (core i7 2.4Ghz, 8Go RAM) the madsonic 5.1 techdemo III, and on my raspbmc the madsonic addon-on video. The server is contacted trough the local IP, no https.
Both devies are on the same LAN, and when I try to reach the madsonic server from the addon, nothing happens but timeout annoucement! So, no Library is displayed, and I can't play any movies owned.
Is there any issue with the techdemo version? How to consult the madsonic addon logs?
Thanks a lot for the hard work!
PS: any chance to have cover art with movies library (like KODI)?
addseo1115
Unread post by addseo1115 »
VikingOy
Has thanked: 3 times
Unread post by VikingOy »
Madevil wrote:
INFO
WARNING
  • restart madsonic
  • rescan files
WINDOWS
TOMCAT
LINUX
    [#] javac -version
    15. Done! :D
linux Defaults
  • stop service
  • start service
  • make full scan
  • stop daemon
  • start daemon
  • make full scan
Hi, any chance of a complete QPKG installation package for QNAP soon?
Sent from my SM-G900F using Tapatalk
