Madsonic Server 6.3 Synology-DSM 6.1.2
Posted: 03 Jul 2017, 18:30
Madsonic 6.3 on Synology
http://www.synology.com
tested with: DSM 6.1.2.15132
  • Perl
  • Java Manager 8
Installation:
  • prepare Synology hardware
  • update to latest Synology DSM 6.1.x
  • create new Volume
  • activate user home service
  • install Perl module
  • install JavaManager module
  • download latest Java JDK 1.8.0_131
  • upgrade Java JDK on DSM
  • reboot Synology
  • install Madsonic 6.3 package
  • start Madsonic service
  • logon as admin user
  • set system output to debug
  • check Madsonic log files
Download:
  • DSM Docker
Installation:
  • install Docker module
  • install Madsonic docker image madsonic/ubuntu-madsonic-beta or madsonic/alpine-madsonic
Download:
  • Java Manager 7
  • Tomcat 7
Installation:
  • install Tomcat7 module
  • download latest Java JDK 7
  • mkdir /var/madsonic
  • reboot Synology
  • install Madsonic tomcat war
  • start Tomcat service
Download:
