Madsonic Server 6.x Synology-DSM 5.x NAS Plugin
Answers: 4
Has thanked: 1177 times
Been thanked: 460 times
Madsonic 6.x Synology-NAS PLugin
http://www.synology.com/
tested with
DSM 5.2-5644 Update 2
DSM 5.2-5592 Update 4
  • Perl
  • Java Manager
Installation
  • 01. install Synology
    02. update Synology
    03. create Volume
    04. create shared folder: Public
    05. activate user home service
    06. add read/write access to share/volume
    07. install Perl module
    08. install Java module
    09. download jdk 8u_66
    10. activate Java
    11. reboot
    12. select installation from all publisher
    13. install Madsonic package
Download
lp version = fixed lowercase public folder
Madsonic6.1-B8600-048.spk (simplified installer)
Madsonic6.1-B8550-046.spk (simplified installer)
Madsonic6.1-B8280-044.spk (simplified installer)
Madsonic6.1-B8220-042.spk (simplified installer)
Madsonic6.0-B7960-039.spk
Madsonic6.0-B7960-039lp.spk
Madsonic6.0-B7860-036.spk
Madsonic6.0-B7860-036lp.spk
Madsonic6.0-B7820-035.spk
Madsonic6.0-B7820-035lp.spk
Reason: Update
These users thanked the author Madsonic for the post (total 3):
Override92eevvjaszladie
Rating: 23.08%
muiz
Has thanked: 4 times
Re: Madsonic Server 6.x Synology-NAS Plugin
Unread post by muiz »
It wont let me install.
Says it cant find madsonic folder in the public folder. But its there.
andyfitter
Unread post by andyfitter »
I had the same problem - Seemed to be caused by the fact my public folder was called 'public' and not 'Public'
muiz
Tried to rename public to Public. But still the same error.
andyfitter
Is there a newer build packaged up for Synology yet?
Answers: 4
Please read the following before installing DSM 6.0 Beta.
For evaluation only -- DSM 6.0 Beta is for evaluation purposes only, so we do not suggest installing it in production environments.
You are strongly recommended to read the Known Issues section before installing it. Synology cannot be held responsible for any accidental data loss caused by this beta software.
Not downgradable -- After installation, you will not be able to downgrade the DSM version on your Synology NAS to a previous version.
Help us out! -- If you have questions, discover an issue, or need help, please fill out and submit the Beta Program form.
Your feedback is welcome, but please note that we cannot respond to feedback immediatel
Hi threre,
It seems that DSM beta version 6.0 broke the installer, there will be a new installer for the final release of DSM 6.0.
Alternate:
* DOCKER Image -> https://hub.docker.com/u/madsonic/dashboard/
* TOMCAT Installation -> http://beta.madsonic.org/pages/installation.jsp#war
Answers: 4
keysuck wrote:I am getting an installation failure error message on DSM 6.0 Beta.
2015/12/18 16:43:01 install Madsonic 6.0-B7820-033 failed
[/code]
install script maybe fixed with version 6.0-B7820-035!
can you retry and resend the log with the new installer?
eevv
Been thanked: 6 times
Unread post by eevv »
Works PERFECTLY on my DS415PLAY - soooo happy to find a fully functioning package for my NAS, after trying w/ only medium success to hack together Subsonic stuff. Thank you very much!
These users thanked the author eevv for the post:
eevv
Can Perl be deactivated or uninstalled after Madsonic is successfully installed?
eevv
Occasionally, and always during a scheduled library scan, Madsonic android becomes useless and gives the well -known Null object reference" error. Subsonic app the same. Anything to do about this? Are those scans really starting as if a first-time scan, or are the referring to preexisting database and only noting changes/additions?
eevv
Sometimes, with latest Synology package installed and latest Android app - the queue simply doesn't start, the standard delay of a few second is normal of course, but on these occasions everything appears fine it's just song counter stays on zero and it never starts
muiz
"User Home service is not enabled." :(
Oxize
Unread post by Oxize »
Added Media Folder ( /volume1/music in my case), but songs arent showing up in Madsonic. What to do now?
Edit: The root music folder cant be empty somehow. Put 1 mp3 in it and then it show all up.
Did you guys get a warning from Security Advisor about Madsonic using synology's FFmpeg libary?
Oxize
Any updates soon for this platform? Or we (synology users) going the same direction as Subsonic? If it get updates, on what base will those be released? Monthly? 3 months? 6 months?
I want to know this, before i going to buy license for Madsonic (in the comming months when your guys ready).
eevv
Agreed - already have a lifetime Subsonic license but MORE THAN HAPPY to donate a one-time amount (100EURO for example?) for continued dedication and development of the DS415PLAY/Synology and Android combo - this is the most important software of my life :)
Oxize
Madevil can you answer our questions please?
Oxize
Synology is rolling out DSM 6.0-7321 (official release), and now Madsonic isnt working anymore on my Synology DS214+.
So guys from Madsonic, please update Madsonic, because i cant do anything atm with Madsonic.
If i can help anywhere, let me know. I can do some basic linux, but thats it. If i need to test something, let me know.
It sucks, that i cant do nothing anymore with Madsonic. I liked this program so much :(
Oxize
Can i read out somewhere a log what is wrong?
editfish
Unread post by editfish »
Same problem here with my DS-415+. So annoyed when the DSM incremental update broke madsonic. Hope this gets resolved soon! :( :( :(
Oxize wrote:Synology is rolling out DSM 6.0-7321 (official release), and now Madsonic isnt working anymore on my Synology DS214+.
HolgerWill
New DSM Update 6.0-7321 Install Error
Unread post by HolgerWill »
After a while during the installation the messge appears, that "The User Home serivce is not enabled"
BUT it defenitly is. I also tried disable and enable it.
Is there help for this??
I really would like to have Madsonic back.
