Add "New added" unders Songs on main screen of Android App
etyrnal
Has thanked: 31 times
Been thanked: 11 times
Unread post by etyrnal »
:idea: One feature i would LOVE to see (and i'll provide the reasoning for it), would be:
PLEASE ADD "New Added" under Songs in the main screen. Just like it is in albums how you can select "New added".
Reason: when i upload new songs to the server, i'd like the most recently added songs to show up when i click "New added" under Songs instead of having to hunt them down and create a playlist... or make an auto generated playlist called "Newly Added Songs" :idea:
etyrnal
Re: Add "New added" unders Songs on main screen of Android A
does anyone else see the value in this?
The purpose is this...
Say over that last few months you've added several songs to the server, and you'd kind of like to here those newer songs, instead of having to search for them one by one, and add them to a playlist, one by one... On the Madsonic Android Client, you'd be able to, under Songs, select "New Added", and it would add the most newly added songs to the play queue... the number of songs would be dependent on the "Search Display Settings", "Max Songs"
Decent idea??
Is there a way to make feature requests community-vote-able?
is added with version 5.5, beta test start soon.
etyrnal
etyrnal
Madevil wrote:hi there,
Great! Super!!
Will version 5.5 (android) have to be purchased again?
Great! Super!!
no, all updates are free on all stores! :D
Should i make a beta channel on the play store ? than people can join the early adopter test version.
etyrnal
rmnma
Been thanked: 5 times
Unread post by rmnma »
That is a very good idea!
Sent from my GT-I9300 using Tapatalk
These users thanked the author rmnma for the post:
etyrnal
mlutzow
Has thanked: 10 times
Unread post by mlutzow »
Excellent Idea!
These users thanked the author mlutzow for the post:
etyrnal
etyrnal
