[Solved] Download option causes corrupt zip files
Mission accomplished!
TastyJams
Been thanked: 22 times
Unread post by TastyJams »
VERSION: MADSONIC 6.0 | BUILD: 7520
SERVER: CPU: XEON E3 | ARCH: X64 | MEMORY: 12GB | HDD: 4TB
OS: LINUX MINT 17.2
SYSTEM: SERVER
INSTALLER: UBUNTU
JAVA: ORACLE JDK 1.8
BROWSER: CHROME 44/FIREFOX 40
DESCRIPTION: "Download" option causes corrupt zip files on some albums.
REPRODUCIBLE: YES
When downloading some albums, the zip file comes out corrupted and will not open. File size of zip file seems to be correct. When downloading each track individually all tracks download fine. Tested on albums that I know downloaded just fine in 5.2 builds.
TastyJams
Re: [Solved] Download option causes corrupt zip files
As of build 7760, the issue seems to be fixed for the most part. Thank you!
HOWEVER, when downloading multiple albums through the play queue download option (for instance, when an entire collection from one artist is added to the play queue), I am still getting corrupted archives.
Also, it it possible to add a download option under each artist in order to allow users to download full collections of each artist (you can already add all albums to play queue at once) instead of having them go through and download each album individually? Either that or would it be possible to have the play queue download option sort each track downloaded into individual artist and/or album folders? This would be a very powerful option.
Thank you again for your hard work!
