[Solved] Server returns wrong error message for client REST
Mission accomplished!
troycarpenter
Has thanked: 28 times
Been thanked: 50 times
 VERSION:      MADSONIC 6.0 | BUILD: 7160
 SERVLET:      JETTY 8.y.z-SNAPSHOT
 SERVER:       CPU: AMD
 OS:           Linux MINT (DEBIAN/Ubuntu)
 SYSTEM:       CLIENT
 INSTALLER:    DEB | RPM | DOCKER | OTHER
 JAVA:         1.7.0_79
 BROWSER:      CHROME 45
 CLIENT:       MADSONIC 5.7.364
 DESCRIPTION:  LDAP not supported
 REPRODUCIBLE: YES
Maybe I'm misunderstanding the way this works, but I tried sending a REST authentication message with the REST version as 1.10.5 (from the previous server version) as follows:
https://myhost.com/rest/ping.view?u=bob&p=pass&v=1.10.5&c=myapp&f=xml
The response was:
<madsonic-response xmlns="http://madsonic.org/restapi" status="failed" version="2.0.0">
<error code="30" message="Incompatible Madsonic REST protocol version. Server must upgrade."/>
</madsonic-response>
I was expecting the response to be error 20: Client must upgrade.
troycarpenter
Re: Server returns wrong error message for client REST versi
Looks like this is fixed with the new emulation code in 6.0.7450.
Client asking for higher version than server supports:
http://myhost.com/rest/ping.view?u=bob&p=pass&v=2.0.5&c=myapp&f=xml
<subsonic-response xmlns="http://subsonic.org/restapi" status="failed" version="1.13.0" type="subsonic">
<error code="30" message="Incompatible REST protocol version. Server must upgrade."/>
</subsonic-response>
Client asking for lower version than server supports (using new rest2 api):
http://myhost.com/rest2/ping.view?u=bob&p=pass&v=1.13.0&c=myapp&f=xml
<madsonic-response xmlns="http://madsonic.org/restapi" status="failed" version="2.0.0" type="madsonic">
<error code="20" message="Incompatible REST protocol version. Client must upgrade."/>
