Having a lot of internal server errors
Ksmoove
Unread post by Ksmoove » 05 Feb 2014, 18:50
My mad sonic installation has been going down a lot and seems to be an input/output error on the log file every time
Exception	org.springframework.jdbc.CannotGetJdbcConnectionException
Message	Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
Java version	Oracle Corporation 1.7.0_51
Operating system	Linux 3.11.0-15-generic
Server	jetty/8.y.z-SNAPSHOT
Memory	Used 138 of 290 MB
Stack trace	org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:82)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
	at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
	at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
	at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:76)
	at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:131)
	at net.sourceforge.subsonic.controller.MultiController.login(MultiController.java:104)
	at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
	at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
	at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
	at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
	at java.lang.Thread.run(Thread.java:744)
Caused by: java.sql.SQLException: File input/output error: /var/madsonic/db/subsonic.log
	at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
	at org.hsqldb.jdbc.jdbcConnection.(Unknown Source)
	at org.hsqldb.jdbcDriver.getConnection(Unknown Source)
	at org.hsqldb.jdbcDriver.connect(Unknown Source)
	at java.sql.DriverManager.getConnection(DriverManager.java:571)
	at java.sql.DriverManager.getConnection(DriverManager.java:187)
	at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:174)
	at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:165)
	at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:149)
	at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
	at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
	... 76 more
triptol
Been thanked: 8 times
Re: Having a lot of internal server errors
Unread post by triptol » 21 Apr 2014, 02:04
Make sure your tomcat / jetty user has rights to that file (and at least access rights to all the folders above).
I often throw away a log file in this situation (or move it away), so the server, after a restart, can create a new one. If it doesn't, you know you have some issue with your file system rights.
