Last.fm scrobbles
HeavensNight
Has thanked: 4 times
Last.fm scrobbles
Unread post by HeavensNight » 23 Dec 2013, 08:16
Madsonic/Subsonic scrobbles songs to last.fm the very second you start listening to it. This is pretty annoying if you're skipping or checking songs.
This is a old issue, just musicCabinet is fixed.
Thanks.
Has thanked: 1122 times
Been thanked: 434 times
Re: Last.fm scrobbles
Unread post by Madsonic » 23 Dec 2013, 13:46
I add this to the todo list, this should work for preloaded files too.
Has thanked: 11 times
Been thanked: 105 times
Unread post by gurutech » 23 Dec 2013, 15:23
I think I saw somewhere in the settings (or maybe just read about it in the forums) that you can set last.fm to not scrobble a song until it has been playing for 30 seconds.
Now that I'm thinking about it, it may have been in the iSub app for the iPhone/iPad.
dackee
Unread post by dackee » 06 May 2014, 04:46
How far away is this?
rolle
Unread post by rolle » 09 Aug 2016, 10:59
I'm still experiencing this... using the latest 6.1.
