Testers
newburns
Been thanked: 10 times
Testers
Unread post by newburns » 03 Jul 2013, 16:58
Madevil,
what are you looking for exactly with testers?
I am going to set up a couple VM's to start testing some of my favorite Open-Source, and Madsonic is towards the top of the list. What do you need from the testers? How to report bugs effectively?
These users thanked the author newburns for the post:
Has thanked: 1146 times
Been thanked: 447 times
Re: Testers
Unread post by Madsonic » 03 Jul 2013, 17:54
Well, Beta 4 is coming and a lot of new changes, fixes should be tested out.
Everybody can help find bugs and report: error messages, screenshots, exceptions or log-files can help a lot
to identify some problems.
in the beta phase i use many snapshot library builds, so problems with newer libraries can cause some errors.
also new versions of sub components like ffmpeg have sometimes heavy code change to newer versions.
This guide help how to Report Bugs Effectively ;)
http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
