Unable to add tracks to playlists (5.0.3840)
e1z0
Unread post by e1z0 »
Hello, and thanks for the great music streaming service software! But I have a problem..
First of all I'm new to madsonic, just two days of usage, before i was using subsonic, and it worked fine with playlists.
On madsonic I was unable to add tracks to any of created playlists, logs does not show anything wrong, then i click on edit playlist i got "Playlist is empty".
Database result shows the same...
SELECT * FROM playlist
shows FILE_COUNT 0 on all created playlists.
Has thanked: 11 times
Been thanked: 105 times
Re: Unable to add tracks to playlists (5.0.3840)
Unread post by gurutech »
If you have a backup of your playlists, you'll need to delete the ones that are empty, and reimport the lists from your backup. I have to do this occasionally, especially after I lose connection to my media folders.
e1z0
I don't have any backups. I Created new playlists with madsonic.
